Calculating Geosynchronous Satellite Orbit and Velocity
  • Thread starter runningirl
  • Tags
    Satellite
In summary, the conversation discusses how to determine the radial orbit and velocity for a geosynchronous satellite in orbit around the earth. The conversation mentions using the equations F=GMm/r^2 and F=mv^2/r to find the orbital radius and velocity, and taking into account the condition that the orbit is geosynchronous. The correct method involves using the sidereal day as the period and solving for r in the equation r=GM/v^2, where v is the velocity. The final answer for the orbital radius is approximately 42,226,910.18 meters. The concept of circular orbit is also brought up, but it is not necessary for solving the problem.
runningirl
118
Determine the radial orbit and velocity for a geosynchronous satellite in orbit around the earth. Remember that geosynchronous satellites are located directly above the equator and they remain above a fixed point on the equator as the Earth rotates
what does radial orbit mean?!
i guess i'd have to find the distance between Earth and the satellite which is 6.38(10^6)+a?
then i'd do F=GMm/r^2 to find F which i could then use for F=mv^2/r find velocity.
Radial orbit probably just means circular orbit.
You are right to bring in these two equations, although it might be more useful to express the second one in terms of radial velocity, omega. I don't know what this means, by the way:
"i guess i'd have to find the distance between Earth and the satellite which is 6.38(10^6)+a?"
But you need to bring in the condition that the orbit is geosynchronous. What does that say about the radial velocity?
Probably just a typo for "orbital radius"
how would i find radial velocity??is it the same as the earth's?
because it says nothing about radial velocity on the problem.
You are looking for the orbital radius and the angular velocity of the radius vector.
The radial velocity (the rate by which the *length* of the radius vector changes) of a circular orbit is zero.
Thanks gneill, I meant angular velocity, omega.
You know that the satellite stays over the same point on the Earth's surface. What would the angular velocity have to be relative to the Earth to accomplish that?
so, i took F=GMm/r^2 and F=mv^2/r and set them equal to each other to find r.
then i found the velocity using the T=2pi(r)/v equation (since T=86400 s).
is this method correct?!
Very close. You should be using the sidereal day as opposed to the mean solar day (86400 seconds) as the period.
okay, i got something REALLY big.
r=6.67*10^-11(5.97*10^24)/v^2
86400=2*pi*(6.67*10^-11(5.97*10^24)/v^2)/v
v=3070.8 m/s
V=2pi*r/T
3070.8=2pi*r/86400
r=42226910.18m
circular orbit=2pi*r
=265319501.6m?
Hidden somewhere amidst your answer is the correct answer, or something close to it.
Explain each step.
i set F=GMm/r^2 and F=mv/r^2 equal to one another and found that r=GM/v^2...
i then took that r (r=6.67*10^-11(5.97*10^24)/v^2) and did T=2pi*r/V.
v=3070.8 m/s
V=2pi*r/T (i did this to find the radius)
3070.8=2pi*r/86400
r=42226910.18m
=265319501.6m?
What question are you trying to answer with the last bit (the part starting with "circular orbit=2pi*r")?
isn't circular orbit= 2*pi*r?
The circumference is 2*pi*r. Were you ever asked to find the circumference?
well then... how do i find the circular orbit?
They probably just want the radius, r, also called the orbital radius. Calculating the circumference is not necessary.
FAQ: Calculating Geosynchronous Satellite Orbit and Velocity
1. What is a geosynchronous satellite?
A geosynchronous satellite is an artificial satellite that orbits the Earth at the same speed and direction as the Earth's rotation, allowing it to remain stationary above a specific location on the Earth's surface.
2. How does a geosynchronous satellite stay in orbit?
A geosynchronous satellite stays in orbit through a balance between the centrifugal force of its orbital speed and the gravitational force of the Earth. It is also continuously monitored and adjusted by ground control to maintain its orbit.
3. What are the uses of geosynchronous satellites?
Geosynchronous satellites are used for a variety of purposes, including communication, weather monitoring, navigation, and surveillance. They are also used for remote sensing and scientific research.
4. How high above the Earth's surface do geosynchronous satellites orbit?
Geosynchronous satellites orbit at an altitude of approximately 22,236 miles (35,786 kilometers) above the Earth's surface.
5. Can geosynchronous satellites be moved to a different orbit?
Yes, geosynchronous satellites can be moved to a different orbit, but it requires a significant amount of fuel and precise calculations to maintain its position above the Earth. Therefore, it is not a common practice unless necessary.
