pellis
- 58
- 8
- TL;DR Summary
- This is a carefully-worded question, from a chemist, about calculating group representation matrices from basis vectors/functions, both in real space and, correspondingly, for the related Hilbert space of solutions.
Being myself a chemist, rather than a physicist or mathematician (and after consulting numerous sources which appear to me to skip over the detail):
1) It’s not clear to me how one can go generally from a choice of basis vectors in real space to a representation matrix for a spatial symmetry group (ignoring the later issue of finding irreps).
Let’s consider a rigid pyramidal ammonia molecule (ignoring internal dynamics, such as vibration modes, etc.) whose symmetry group is C3v. [NB The C3v case is simple enough that the matrix reps can be identified without using a general procedure – but it’s the general procedure this question is asking about]
Presumably, one can choose a real-space basis a-priori (orthogonal unit vectors along the three axes with z vertical; or, better perhaps, two unit vectors at 120-degrees plus the vertical z-unit vector).
How does one then calculate the representation matrix for each symmetry operation of the group?
This is, presumably, pure classical physics – no quantum mechanics required.
2) Having subsequently solved some semi-empirical approximations to the Schrödinger equation for the ammonia molecule, one obtains a set of molecular orbitals (eigenfunctions) in a Hilbert space.
The eigenfunctions should display the same symmetries as the classical molecule (and, anyway, we’ve likely used the ‘classical’ spatial symmetries already, in setting up the calculation).
If we now choose the molecular orbital eigenfunctions/eigenvectors that form a basis in Hilbert space as basis functions/vectors for symmetry purposes, then:
How does one then calculate the representation matrix for each symmetry operation of the group using the molecular orbital basis?
(and in general, how do the resulting eigenvectors (molecular orbital functions) and representations of the symmetry operations relate to those in the answers to (1) above?
NB This is NOT a question about irreducible representations, but about the stage before they are considered.
An equally carefully-worded reply will be greatly appreciated.
Thank you for reading this far, and Happy New Decade to all.
