Calculating how much heat must be added to increase temp
  • Thread starter Thread starter john ryan
    Heat increase
To raise the temperature of 3.5 m³/s of moist air from 10°C to 27°C, specific calculations involving heat transfer and properties of moist air are necessary. The required heat can be determined using the specific heat capacity of air and the moisture content at the initial conditions. After heating, the new relative humidity must be calculated based on the increased temperature and the moisture content. Additionally, the power required for the heating unit can be derived from the total heat added over time. For further assistance, it's recommended to repost in the homework help forum with an attempt at the solution.
john ryan
Can anyone help me with this?
-How much heat must be added to 3.5 m3 /s of moist air with a dry bulb temperature of 10°C and a relative humidity of 60% to raise the temperature of the air by 17°C?
• What will be the relative humidity of the air once this heat is added?
• What is the power required in the heating unit?
Science news on Phys.org
Please re-post this in the homework help forum, follow the template and make an effort to try and solve it yourself. Thread locked.
Likes davenn
Thread 'Thermo Hydrodynamic Effect'
Vídeo: The footage was filmed in real time. The rotor takes advantage of the thermal agitation of the water. The agitation is uniform, so the resultant is zero. When the aluminum cylinders containing frozen water are immersed in the water, about 30% of their surface is in contact with the water, and the rest is thermally insulated by styrofoam. This creates an imbalance in the agitation: the cold side of the water "shrinks," so that the hot side pushes the cylinders toward the cold...
