SteveGlow
- 1
- 1
Hi,
First, I want to thank ahead of time any help that can be provided. Second, I'm just an advanced tinker'r needing help on a project.
Description:
-Lever 1 and Clamp are attached
-Lever 2 and Rod 2 are attached.
-Clamp is tightened around Rod 2
-Upward force on end of Lever 2 needs to be at least 90 lbs without Clamp slipping.
What I've tried to do:
1. Calculate the Clamping Force using the equation from:(https://www.engineersedge.com/calculators/torque_calc.htm)
Bolt Major Dia: .3125"
Coef Friction: .2 (steel)
Calculated Axial bolt clamp force = 800 lbs
2. Calculate the Needed Clamping Force using the equation in posting:
(https://www.physicsforums.com/threads/determining-the-clamping-force-on-a-tube.558240/)
F_clamping X Radius_tube = F_applied X Larm or
F_Clamping = (F_applied X Larm) / Radius_tube
= (50 lbs x 2.756") / .237"
= 581.435 lbs
Summary:
Since the Clamping Force of 800 lbs exceeds the needed F_Clamping of 581 lbs, this scenario should be successful.
Is all of this correct?
I do wonder if the 160 deg angle affects this. Also, how does the contact square area of the clamp come into play on frictional force?
Thanks Again!
Description:
= 581.435 lbs
Summary:
Thanks Again!
