Calculating Impulse and Momentum in a Colliding Cart System
  • Thread starter dorkymichelle
In summary, the problem involves two carts, one with a mass of 2 kg and a speed of 3 m/s, and the other with a mass of 4 kg and stationary. After colliding, the carts stick together and the impulse exerted by one cart on the other is equal to the change in momentum for that cart, which is determined by the conservation of momentum equation.
dorkymichelle
40
A 2-kg cart, traveling on a horizontal air track with a speed of 3 m/s, collides with a stationary 4-kg cart. The carts stick together. The impulse exerted by one cart on the other has a magnitude of:
Momentum=mv
impulse = Favg*delta t
Impulse = final momentum - initial momentum
P= momentum
Pi=Pf
m1Vi=(m1+m2)Vf
(2)(3)=(2+4)Vf
Vf=1
Can I say that momentum is conserved so impulse = 0 in this case?
Also, in class, we said that momentum is always conserved so that means Pi=Pf, so how can there be an impulse if impulse is the change in momentum and momentum doesn't change if momentum is always conserved?
You need to think about this one. The conservation of momentum means that the sum of the beginning momenta equals the sum of the final momenta.
So, in this form, the equation becomes
m1v1 + m2v2 = m1v3 + m2v3, which is the same as
p1beginning + p2beginning = p1final + p2final.
The impulse is the change of momentum for one cart. The impulse the 4 kg cart exerts on the 2 kg cart is the difference of the momentum for the latter one, and vice versa.
FAQ: Calculating Impulse and Momentum in a Colliding Cart System
1. What is the difference between impulse and momentum?
Impulse refers to the change in momentum of an object, while momentum is the measure of an object's motion and is equal to its mass multiplied by its velocity.
2. How is impulse related to force?
Impulse is equal to the force applied to an object multiplied by the time in which it is applied. This relationship is described by the equation J = FΔt.
3. What is the principle of conservation of momentum?
The principle of conservation of momentum states that in a closed system, the total momentum before and after a collision remains constant. This means that the sum of all the momenta of the objects involved in the collision is equal before and after the collision.
4. How does impulse affect the motion of an object?
When an object is subjected to an impulse, its momentum changes. This change in momentum can result in a change in the object's velocity or direction of motion.
5. How is impulse calculated?
Impulse is calculated by multiplying the average force applied to an object by the duration of the force's application. It can be represented by the equation J = FavgΔt.
