Calculating income after taxes - how?
In summary, if you are in a situation where you will be making more money in the next year or two, you should try to calculate your tax liability by using an online calculator or using your income and your state's tax rate.
KingNothing
881
Hello all! I am in a position where I am likely to be making quite a bit more money in the next year or two than I have previously. I would like to plan my finances around this and estimate me income after taxes.
Is there an online calculator I can use to calculate such a thing? How can I figure this out ahead of time?
This will help you with your federal: http://www.irs.gov/individuals/page/0,,id=14806,00.html
You should also try to figure out your state, as well.
If you only have one source of income (your job), then simply declaring the proper number of dependents on your W-4 should be sufficient. Otherwise, it's good idea to estimate what your federal and state income taxes will be and then check to make sure you're having enough deducted each pay period (or paying enough in estimated taxes each quarter) that it comes close to what you'll owe at the end of the year.
If you are in the US, don't forget social security and medicare.
Its actually pretty easy: if you're in the $37-$80k bracket your marginal rate is 30% and the fica+med is 5.6%. Then add any flat state or local taxes and your 401k. Typical total would be around 45%.
I only use the simplified tax form:
1. How much did you make?
2. Send it to us. Many or any tax calculating software should work.
Just input your numbers and ...
It you need to work out exactly what your income after tax is, then it's too small.
Yes, definitely don't forget your other paycheck withholdings/payments (Insurance, 401k, Stock Purchase etc).
Unless you're extremely tight to start, you may be better off just seeing what your first pay check comes out to and extrapolate. That will likely be a bit more accurate than taking into account all of the little taxes, fees, etc at the appropriate rate.
eg: if you're clearing $1500 in your first check and you get paid twice a month, you would have $36k for the year in pocket.
If you do choose to computer your taxes, remember that the rate is marginal. Single tax rate for $34,001 – $82,400 is 25%. But... $8,376 – $34,000 is 15% and less is 10%. You'll also have a standard deduction of about 10k off the top, so your tax-liable income is probably 10k less than your yearly salary.
Presuming you fall into the bracket above you're really looking at:
8375*.10 + (34000-8375)*.15 + ([your income minus ~$10k std deduction] - 34000)*.25
So your real income tax rate at $34,002 is still in the low teens (just $2 are taxed at 25%, and the 8375 is at 10%).
http://en.wikipedia.org/wiki/US_Income_tax#Year_2010_income_brackets_and_tax_rates
I didn't mention insurance because it tends to be a fixed amount, not a percentage.
What I do since I get paid by the hour is calculate a marginal pay rate from two paychecks. Ie, if the takehome on one is $1000 for 40 hours and the takehome is $1040 for 42 hours, the marginal rate is (1040-1000)/(42-40)=$20/hr.
That's useful for figuring out how much more or less I'm going to get based on my overtime for a certain pay period.
Related to Calculating income after taxes - how?
1. How do I calculate my income after taxes?
To calculate your income after taxes, you will need to gather information about your total income for the year, including any wages, bonuses, and investment income. Then, subtract any pre-tax deductions, such as retirement contributions or healthcare premiums. Next, determine your taxable income by subtracting any applicable deductions and exemptions. Finally, use a tax rate table or calculator to determine your tax liability, and subtract that amount from your taxable income to get your income after taxes.
2. What is the difference between gross income and net income?
Gross income is the total amount of income you earn before any deductions or taxes are taken out. Net income, on the other hand, is your income after all deductions, including taxes, have been taken out. This is the amount of money you actually take home and can use for expenses and savings.
3. Are all types of income subject to taxes?
No, not all types of income are subject to taxes. Some examples of non-taxable income include certain types of retirement income, workers' compensation, and child support payments. Additionally, some states do not have a state income tax, so income earned in those states would not be subject to state income taxes.
4. How do deductions and exemptions affect my income after taxes?
Deductions and exemptions can significantly impact your income after taxes. Deductions are expenses that can be subtracted from your taxable income, such as mortgage interest or charitable donations. Exemptions, on the other hand, are amounts that can be deducted from your taxable income for each dependent you claim. These deductions and exemptions can lower your taxable income and ultimately reduce your tax liability, leaving you with a higher income after taxes.
5. Can I use tax software to calculate my income after taxes?
Yes, tax software can be a helpful tool for calculating your income after taxes. Many tax software programs will walk you through the steps of entering your income and deductions and will automatically calculate your tax liability. However, it is important to review the information entered to ensure accuracy and to consult with a tax professional if you have any questions or complex tax situations.
34K
