Calculating Inductance for 5kV Flyback Converter in 1mS
In summary, the required inductance for a flyback inductor used in a boost converter to produce 5kV across it in 1mS with a current of 10mA can be calculated using the formula V=L di/dt, where di/dt is the rate of change of current. However, caution must be taken when building high voltage inductors as it requires special expertise and materials. The primary inductance does not directly affect the boost voltage, but together with the peak current, it determines the amount of energy that can be transferred on each cycle. Measures must also be taken to prevent the secondary voltage from damaging the primary side.
hobbs125
108
I am wondering, In a flyback inductor used for a boost converter, what inductance would be required to produce 5kV across the flyback inductor in 1mS with a current of 10mA?
I know the formula would probably be V=L di/dt but I'm not sure how to rearrange it to get the correct answer.
hobbs125 said:
I am wondering, In a flyback inductor used for a boost converter, what inductance would be required to produce 5kV across the flyback inductor in 1mS with a current of 10mA?I know the formula would probably be V=L di/dt but I'm not sure how to rearrange it to get the correct answer.
di/dt is simply the rate of change of current which you defined as 10A/sec. Solve for the inductance L in Henries.
Please exercise caution if this is other than an academic exercise. And, aside from the obvious safety hazards, building high voltage inductors requires other expertise - special insulating materials, placement, etc.
H=V.s/A refer this
http://en.wikipedia.org/wiki/Henry_(unit )
The Flyback boost voltage doesn't really depend on the primary inductance.
The primary inductance together with the peak current defines the amount of energy (not voltage) that the coil can transfer on each cycle.
When the main switch opens, you can treat that as instantaneous. L di/dt can be huge. In a real Flyback, you allow the secondary voltage to go up to some particular voltage by connecting the secondary to a capacitor.
If for some insane reason you want the secondary voltage to go really high, you have to take steps to make sure that voltage isn't transformed back to the primary side where it will probably destroy the switch.
FAQ: Calculating Inductance for 5kV Flyback Converter in 1mS
1. How do you calculate inductance for a 5kV flyback converter in 1mS?
To calculate the inductance for a 5kV flyback converter in 1mS, you will need to use the equation L = V * T / ΔI, where L is the inductance in Henrys, V is the input voltage in volts, T is the time in seconds, and ΔI is the change in current in amperes. Make sure to use consistent units when plugging in values.
2. What is the purpose of calculating inductance for a flyback converter?
Calculating inductance for a flyback converter is important because it helps determine the proper value for the inductor in the circuit. The inductance value affects the converter's efficiency and performance, so it is crucial to calculate it accurately.
3. Can I use the same inductance value for different input voltages and time periods?
No, the inductance value will vary depending on the input voltage and time period. It is essential to recalculate the inductance value for each specific scenario to ensure optimal performance of the flyback converter.
4. What happens if the inductance value is too low or too high?
If the inductance value is too low, the flyback converter will experience higher currents, leading to higher losses and lower efficiency. On the other hand, if the inductance value is too high, the converter may not operate correctly, and the output voltage may be unstable or too low.
5. Are there any other factors that may affect the calculation of inductance for a flyback converter?
Yes, other factors such as the frequency of the input signal, the type of inductor used, and the load current can also affect the inductance calculation. It is important to consider all these factors when calculating the inductance value for a flyback converter.
