Calculating Insulation Thickness for a Building (Engineering)
In summary, the conversation discusses how to calculate the optimum thickness for insulation in a single room building that is heated using standard space heaters. The building is maintained at a temperature of 18-23°C and each wall is constructed with 2 layers of common brick, an internal particle board, and a layer of insulation. The cost of gas and materials are also taken into consideration. To calculate the energy cost, it is necessary to know the outdoor temperatures and use equations to find the total energy needed and corresponding cost.
btec_noob
A single roomed building measureing 12.0m x 12.0m x 2.5m is maintained throughout the day at a temperature of between 18-23°C. Each wall is to be constructed from 2 layers of common brick, an internal particle board and a layer of insulation. The building is heated using standard space heaters that will run on natural gas. The gas currently costs 7p/kWh and is burnt at an efficiency of 70%. During heating calculations it is assumed that the same thickness of insulation is applied to floor, wall and roof and that mineral wool at a current price of £55/m3 is utilised. Calculate the the optimum thickness for insulation over a 12 months period.
q = ΔT/∑Rth
therefore: q with insulation/q without insulation = 0.3 = ∑Rth (with)/∑Rth (without)
Thermal resistance Rth = Δx/k
So far I've assumed that due to it being over 12 months, there will be a change in outside temperature during the different seasons. Also assumed that there is no air gap between the wall. The k values I have found so far are: brick = 0.7, particle board = 0.15 and k for wool is 0.04, so I can calculate the Thermal resistance and heat loss.
R wool = L/kA = x/0.4*1 = x/0.4 °C/W
R brick = L/kA = 0.1/0.7*1 = 1.429*2 = 0.2858 °C/W
R P.board = L/kA = 0.01/0.15*1 = 0.067 °C/W
I just need help in finding the equation for calculating Energy cost.
so I can calculate the Thermal resistance and heat loss... I just need help in finding the equation for calculating Energy cost.
In order to maintain a constant temperature the energy supplied by the heating must equal the heat loss through the structure. So calculate the energy loss over a year in Joules. The same amount of energy must be delivered by the gas heating.
Because the heating is not 100% efficient more energy must be supplied from the gas main than calculated above so do that calculation.
Once you have a figure for the total energy needed (in Joules) remember that:
1 Watt = 1 Joule per second
or
1 Joule = 1 Watt for 1 second
You have been provided a cost figure of 7p/kWh so a bit more work is needed to arrive at the total cost in pence.
You will also need to know something about the outdoor temperatures where the building is located. An average winter outdoor temperature is a start but not very accurate, average temperature by month would be better, heating degree days are also used, bin data is also used.
Related to Calculating Insulation Thickness for a Building (Engineering)
1. What is insulation thickness and why is it important in building engineering?
Insulation thickness refers to the thickness of material used to insulate a building. It is important in building engineering because it helps regulate the temperature inside the building, reducing the need for heating and cooling and thus saving energy and money.
2. How do you calculate the required insulation thickness for a building?
The required insulation thickness for a building can be calculated by considering several factors such as the desired indoor temperature, climate conditions, building materials, and energy efficiency goals. This calculation can be done using specialized software or by consulting building codes and standards.
3. What types of insulation are commonly used in building engineering?
There are several types of insulation that are commonly used in building engineering, including fiberglass, cellulose, foam board, and spray foam. Each type has its own advantages and disadvantages, and the choice of insulation will depend on the specific needs and requirements of the building.
4. Can insulation thickness vary throughout a building?
Yes, insulation thickness can vary throughout a building depending on the specific needs of each area. For example, areas that are exposed to extreme temperatures may require thicker insulation, while areas with minimal temperature fluctuations may require less insulation.
5. What are the potential consequences of incorrect insulation thickness in a building?
Incorrect insulation thickness can lead to several consequences, such as higher energy bills, uncomfortable indoor temperatures, and increased risk of mold and moisture issues. It can also impact the overall energy efficiency and sustainability of the building.
