MHB Calculating Joint Probability - Get the Answer!
  • Thread starter Thread starter Usagi
    Joint Probability
The discussion revolves around understanding the calculation of joint probabilities, specifically how to derive the boxed expression in the provided image. Participants clarify that the joint probability of different variables can be shown to be equal due to the arbitrary nature of their labeling. It is noted that \(P(X_j=1,X_k=1)\) can be expressed in terms of \(P(X_1=1,X_2=1)\) and that this equality holds across different indices. The conversation emphasizes that the probabilities remain consistent regardless of the variable labels, allowing for permutations in the indices. Overall, the thread provides insights into the principles of joint probability calculations.
Usagi
http://img151.imageshack.us/img151/6002/variance.jpg
Just wondering, how did they get the part boxed in blue?
Thanks.
Mathematics news on Phys.org
Thanks.
The part in the box comes from the observation that:
\[P(X_j=1,X_k=1)=P(X_1=1,X_2=1), \ \ j\ne k\],
and that:
\[P(X_1=1,X_2=1)=P(X_1=1)+P(X_2=1|X_1=1)\]
CB
Thanks for that, I realized it too however how does one show that $P(X_j, X_i) = P(X_1, X_2) = P(X_1, X_5)$ and so on?
It isn't so obvious to me that $P(X_1, X_2) = P(X_1, X_5)$
The informal explanation is that as the labelling is essentialy arbitary the probabilities are all the same.
More formally:
\[P(X_1=1,X_2=1)=P(X_2=1)+P(X_2)P(X_1=1|P(X_2=1)\]
But \(P(X_2=1|X_1=1)=P(X_2=1|X_5=1)\) and \(P(X_2=1)=P(X_5=1)\). which look better but is still just an observation that the idexing is arbitary and you can just permute indices.
CB
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
