Calculating KE in rotational motion
In summary, the conversation discusses calculating the total kinetic energy of a 20kg solid disk rolling at 4.0m/s on a horizontal surface. The correct solution involves using both translational and rotational KE, with the formula KE = (1/2)mvcm^2 + (1/2)Iw^2.
MinaHany
A 20kg solid disk (I=1/2Mr^2) rolls on a horizontal surface at the rate of 4.0m/s
Calculate its total kinetic energy
I think that simply equating the KE to (0.5)(m)(v^2) would be a wrong solution because then I would not use the moment of inertia given in the question, although I don't know why it is wrong.
Thank you.
It's wrong because it ignores the rotational KE. The rolling disk has both translational and rotational KE. What's the formula for rotational KE? Hint: How does translational speed relate to angular speed? (Assume it rolls without slipping.)
Use:
KE = KEtranslational + KErotational = (1/2)mvcm2 + (1/2)Iw2
vcm : velocity at the center of mass[sorry Doc Al, I didn't see you post]
Thank you Doc AL and lewando..
Your replies made the idea clear for me.
Your thinking is correct. In rotational motion, the moment of inertia must be taken into account in calculating the kinetic energy. The correct formula for rotational kinetic energy is KE = (1/2)(I)(ω^2), where I is the moment of inertia and ω is the angular velocity. In this case, the moment of inertia for a solid disk is given by I = (1/2)(m)(r^2), so plugging in the values from the problem, we get KE = (1/2)(1/2)(20)(4.0)^2 = 160 J. This is the total kinetic energy of the disk in rotational motion.
FAQ: Calculating KE in rotational motion
1. How do you calculate the kinetic energy in rotational motion?
In order to calculate the kinetic energy (KE) in rotational motion, you must first determine the moment of inertia (I) of the object and its angular velocity (ω). The formula for KE in rotational motion is KE = ½ * I * ω².
2. What is moment of inertia?
Moment of inertia (I) is a measure of an object's resistance to change in rotational motion. It depends on the object's mass distribution and its axis of rotation. Objects with more mass concentrated farther away from the axis have a higher moment of inertia.
3. How do you find the angular velocity?
Angular velocity (ω) is the rate of change of an object's angular displacement. It can be found by dividing the change in angular displacement by the change in time. The unit of angular velocity is radians per second (rad/s).
4. Can you use the same formula for calculating KE in linear motion?
No, the formula for KE in rotational motion (KE = ½ * I * ω²) is different from the formula for KE in linear motion (KE = ½ * m * v²). In rotational motion, the moment of inertia is used instead of mass, and angular velocity is used instead of linear velocity.
5. What is the unit of kinetic energy in rotational motion?
The unit of kinetic energy (KE) in rotational motion is joules (J). This is the same unit as in linear motion, as both types of motion involve energy and work.
