Calculating Launcher Mass from Projectile Acceleration
In summary: The launcher exerted a force on the projectile, making it move. Does it have to be in contact with the launcher in order to not fall or could the force exerted on it horizontally be large enough to allow the projectile to only move horizontally(at least, in the beginning)?In summary, the conversation discusses a problem involving a projectile launcher and a projectile on a frictionless surface. The projectile has an acceleration of 25m/s^2 while the launcher has an acceleration of 0.25m/s^2. The mass of the projectile is given as 0.20kg and the task is to calculate the mass of the launcher. The solution involves using Newton's third law, which states that any action force will produce an equal
Balsam
226
A projectile launcher fires a projectile horizontally from a platform which rests on a flat, icy, frictionless surface. Just after the projectile is fired and while it is moving through the launcher, the projectile has an accelleration of 25m/s^2. At the same time, the launcher has an accelleration of 0.25m/s^2. The mass of the projectile is 0.20kg. Calculate the mass of the launcher.
Given: acceleration of projectile: 25m/s^2[forwards]. Accelleration of launcher: 0.25m/s^2[backwards]. mass of projectile- 0.20kg
Fnet=ma
I have no clue how to solve this. I checked the solution, and according to that, you have to solve for Fnet of the projectile using Fnet=ma, and the net force of the launcher is equal in magnitude but opposite in direction to that of the projectile. Then you use Fnet=ma for the launcher and solve for mass. I don't understand why the net force of the launcher is equal in magnitude but opposite in direction to that of the launcher. Can someone explain?
Newton... action and reaction... any memories stirring?
As haruspex has said, you need to know about Newton's third law
It just says that any action force will produce a reaction force, what does that have to do with net force? The net force inolves gravity in this case, and since the masses of these 2 obects are different, how can you assume that their net forces are equal in magnitude?
right, my mistake,it must be conservation of momentum
We haven't learned that yet, so I don't know how we would be expected to solve this/
i will try figuring a solution
No, i was right, we must use Newton's third law, the mass is different but acceleration is different too
Can you please explain further?
Yes. That is, the force body A exerts on body B is equal and opposite to the force body B exerts on body A.
The net force on a body is from summing all forces acting on the body. Any reaction on it from another body contributes.
There is a gravitational force, but there is also a normal force, which is here guaranteed to be exactly what is need to prevent it falling through the ice, and no more. Thus, can assume they will cancel.
What does that leave for the net force on the platform?
The force that makes the projectile move also affects on the launcher
Are the projectile and the launcher in contact? I don't think so. What normal forces ?
Is there a normal force on each object?
It is the force that perpendiculars to the ground
But they're not both in contact with the ground
By what magic does the projectile move?
By what magic does the platform avoid falling through the ice?
I think god can do that but not human and especially that we are under the influence of physics laws
Could the inner diameter of the launcher not be wide enough so the projectile is not in contact with the launcher? In that case, it would not be in contact with any surface- no normal force
Action and reaction does not necessarily consist of contact forces. What force made the projectile move? What was the launcher's role in that?
If the projectile is not in contact with the launcher at all while moving through the muzzle, what is stopping it from falling?
The launcher exerted a force on the projectile, making it move. Does it have to be in contact with the launcher in order to not fall or could the force exerted on it horizontally be large enough to allow the projectile to only move horizontally(at least, initally)?
Whatever force it exerted on the projectile, and however it exerted it, the projectile exerted an equal and opposite force on the launcher at each instant. The law of conservation of momentum follows from his.
No amount of horizontal force will affect the vertical motion.
Ok, so they must've been in contact
OK, so where are we at in resolving this thread?
This was from a few days ago, but if I remember correctly, I was able to solve the problem.
Ok, I'll mark it solved.
Related to Calculating Launcher Mass from Projectile Acceleration
1. How is projectile acceleration measured?
Projectile acceleration is typically measured using a device called an accelerometer. This device measures the rate of change of velocity of the projectile over time.
2. What is the equation for calculating launcher mass from projectile acceleration?
The equation for calculating launcher mass from projectile acceleration is mass = force/acceleration. This means that the mass of the launcher can be determined by dividing the force applied to the projectile by the acceleration of the projectile.
3. Can projectile acceleration be affected by external factors?
Yes, projectile acceleration can be affected by external factors such as air resistance, wind, and gravity. These factors can alter the trajectory and speed of the projectile, resulting in a different acceleration.
4. How does the shape and size of the projectile affect the calculation of launcher mass?
The shape and size of the projectile can affect the calculation of launcher mass. A larger or more aerodynamic projectile will experience less air resistance, resulting in a higher acceleration. This means that a different mass may be required for the launcher depending on the projectile being used.
5. What are some limitations of using projectile acceleration to calculate launcher mass?
One limitation of using projectile acceleration to calculate launcher mass is that it assumes a constant acceleration throughout the entire flight of the projectile. In reality, acceleration may vary due to external factors such as air resistance and gravity. Additionally, this method does not take into account the mass of the launcher itself, which can also affect the acceleration of the projectile.
