Calculating Magnetic Energy Between Plates
The discussion focuses on calculating magnetic energy between two plates with a current density of J = 1 A/m². The initial approach involves using the vector potential to determine magnetic energy, but there is uncertainty about handling the matter between the plates. An alternative method suggested is applying Ampere's law to find the magnetic intensity H within the material, which can then be used to calculate energy density u. This energy density can be integrated over a defined volume to find the total energy. The conversation highlights the need for clarity in applying these concepts to different scenarios involving magnetic fields and materials.
Roger Dalton
Hello everyone!
Please, could anybody help me solving this exercise? I have some doubts about if my approach is correct:
Two infinite and parallel thin sheets carry equal surface current densities (1 A / m2), uniform and constant. The space between the sheets is occupied by a material of relative magnetic permeability 3. Calculate the pressure exerted on this material if A) The currents circulate in the same direction, B) if they circulate in n opposite directions.
Thanks in advance!
F = -grad(U_m)
The current density between the plates is J = 1 A/m2. So, I have to calculate first the magnetic energy in the whole space. Out of the sheets, there is no current, so the magnetic energy would be 0 in that places. Hence,
U = J(1/2) \int_{inside the plates}A(r)dr, where A(r) is the vector potential inside the plates.
Then, I would apply F = -grad(U), and as the pressure is F/S, I'll get the answer. Would it be correct? However, I don't know how to do that with matter between them.
The first approach I would try is not through the vector potential. I would use Ampere's law to find the magnetic intensity ##H## inside the material, use it to find the energy density ##u##, use it to find the energy inside a box of area ##A## and height equal to the plate separation. I think you know how to proceed from here.
Note: This is another old unanswered thread to be removed from the "unanswered" list.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
