Calculating mass of air displaced in compressor.
The discussion focuses on calculating the mass of air displaced by a pneumatic pump using the equations PV = mRT and P1V1n = P2V2n. The theoretical displacement of 106 l/min translates to 53 l for a 30-second cycle, prompting questions about the relevance of the second equation. It is suggested that using PV = mRT is sufficient, while the other equation's applicability depends on whether the process is isothermal or adiabatic. Clarification is sought on the meaning of the variables and the reasoning behind using n in the equations. The conversation emphasizes the importance of experimental data to determine the nature of the process.
SherlockOhms
So, this question is to do with an experiment which investigates the operations of a pneumatic pump. You're asked to find the mass of air displaced in each 30 second period using the atmospheric pressure, temperature and theoretical displacement of the compressor. Also, you are told to use 2 of following equations: PV = mRT and P1V1n = P2V2n.
Given in question.
Well, the theoretical displacement is given as 106 l/min. Thus for a 30 second cycle, V = 53 l. Does it not make sense just to use PV = mRT for this? How is P1V1n = P2V2n relevant? Thanks.
<< Does it not make sense just to use PV = mRT for this? >>
Don't know why not.
Use dm/dt = (p/RT) dv/dt. R is specific to air of course, not the universal gas constant.
If n = 1, p^n v^n = RT denotes an isothermal process. If n = cp/cv it's an adiabatic process.
You don't know if it's either one so that's another reason I don't see any point in this equation here.
I guess, once I carry out the experiment I can see my values for n and then judge whether it's an isothermal or adiabatic process. Does that sound reasonable?
<<If n = 1, p^n v^n = RT>>
Why is it p^n v^n = RT and not p^n v^n = mRT? Also, why is P raised to the power of n? Think I've lost track of you.
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up ##Mg \sin \theta ## will act downwards and maximum static friction will act downwards ## \mu Mg \cos \theta ## Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
