Calculating masses of unknown quantities of reactants.
  • Thread starter thatguythere
  • Tags
    quantities
In summary: Also, your calculation for moles of BaSO4 was incorrect, so this calculation will also be incorrect.In summary, the goal of the conversation was to calculate the number of moles and mass of BaCl2 and NaCl in an original mixture. This was done by preparing a solution of Na2SO4, adding it to the mixture, and heating it to form a precipitate. However, there were errors in the calculations for the moles and mass of BaCl2, possibly due to incorrect drying of the precipitate. Further adjustments may be needed to accurately determine the masses and mass percent of BaCl2 and NaCl in the original mixture.
thatguythere
91
Calculate the number of moles and mass of BaCl2 and NaCl in the original mixture.
We prepared a solution of 0.35M Na2SO4. We then obtained an unknown mixture of BaCl2•2H2O and NaCl, weighed 1 g and added it to 200 mL of water and 10 mL HCl. Finally we added 10mL of the Na2SO4 solution and heated the mixture for several minutes to form a precipitate which was then dried and weighed. Using the weight of the precipitate, which was 1.769 grams, we are asked to calculate the masses and mass percent of both BaCl2 and NaCl in the original mixture. The chemical equation given is:
BaCl2(aq) + Na2SO4 (aq) → BaSO4(s) + 2Na+(aq) + 2Cl-(aq)
Moles BaSO4= 1.769gBaSO4 x (1 mol BaSO4/233.39gBaSO4) = .00768 moles BaSO4
Since the molar ratio between BaSO4 and BaCl2 is 1:1
Moles BaCl2=0.00768 mol BaSO4 x (1 mol BaCl2/1 mol BaSO4)
= 0.00768 moles BaCl2
Grams BaCl2= 0.00768 mol BaCl2 x (208.23gBaCl2/1 mol BaCl2
=1.60g BaCl2
This is what makes me believe I have done something quite incorrect, since the original mass of my mixture was only 1 gram. Please advise. Thank you.
There is something wrong with your calculations in at least two places, sadly, it doesn't change the problem - mass of the barium chloride dihydrate is higher than the original sample mass. My bet is that you have not dried the BaSO4 correctly, that's the most common error in such cases.
Check your math. Molar mass of BaSO4 is OK, but number of moles isn't.
=1.60g BaCl2
You said you used dihydrate, not anhydrous barium chloride, so the molar mass is incorrect.
Related to Calculating masses of unknown quantities of reactants.
1. What is the first step in calculating the mass of an unknown reactant?
The first step in calculating the mass of an unknown reactant is to determine the balanced chemical equation for the reaction. This will give you the molar ratios between the reactants and products, which are essential for calculating the mass of the unknown reactant.
2. How do you calculate the mass of an unknown reactant using the molar ratio?
To calculate the mass of an unknown reactant, you first need to convert the given amount of a known reactant or product into moles using its molar mass. Then, using the molar ratio from the balanced equation, you can determine the moles of the unknown reactant. Finally, multiply the moles by its molar mass to get the mass in grams.
3. Can the mass of an unknown reactant be calculated without knowing the molar ratio?
No, the molar ratio is essential in determining the mass of an unknown reactant. Without it, you would not have enough information to accurately calculate the mass. It is important to always start by balancing the chemical equation before attempting to calculate any masses.
4. How do you account for excess reactants when calculating the mass of an unknown reactant?
If there is an excess amount of a reactant, it means that not all of it will be used up in the reaction. In this case, you would use the limiting reactant to calculate the mass of the unknown reactant. The limiting reactant is the one that is completely used up in the reaction and determines the amount of product formed.
5. Can the mass of an unknown reactant be calculated using the ideal gas law?
Yes, the ideal gas law can be used to calculate the mass of an unknown reactant in certain situations. This is typically used in gas phase reactions where the volume and temperature are known, and the unknown reactant is a gas. In this case, the ideal gas law equation can be rearranged to solve for the mass of the unknown gas.
9K
10K
21K
