Calculating Mechanical Energy of a Launched Ball
In summary, the ball has 20 joules of mechanical energy when it is exactly at the height of 4 meters.
Pamela Pepper
Hi Everyone,
I can't seem to figure this problem out. Please help!
1. Homework Statement
A ball was launched upwards and vertically at a speed 3 m/second up to a height 4m. Calculate the mechanical energy of the ball if its weight is 5 Newtons and has a mass 0.5kg .
potential energy= mass x gravitational acceleration x height
kinetic energy= 1/2 mass x velocity x velocity
mechanical energy= potential energy + kinetic energy
mechanical energy = potential energy at maximum height
maximum potential energy =mass x gravitational acceleration x maximum height
= 0.5 x 10 x 4
= 20 joules
So, mechanical energy equals 20 joules?
Does this question seem right to everyone?
Many thanks,
Pamela Pepper
Hello PP, :welcome:
You want to sort out the given information, so that you obtain a complete and solvable problem statement.
In your attempt you mention 'maximum height', but: do you know that that maximum is 4 m ?
To me the scenario is a bit unclear: is the 3 m/s at 0 m, or at 4 m height ? My impression is: the latter.
You should use units.
The problem statement is weird. If the ball is launched with 3 m/s at ground level and in free fall afterwards it won't reach a height of 4 m. So where does it have 3 m/s and how are you supposed to take this into account?
I assume they want you to calculate it's mechanical energy when it's exactly reached to a height of h=4m,
You can see that they have given you that the mass is moving with initial velocity ## v_0 ## of 3m/s upwards .
In addition , the only force acting on the mass is gravity , therefore your mass is constrained to move under constant acceleration , so you can solve the problem by using the equation of motion under constant acceleration ## y(t) = y_0 + v_0*t + (a/2)(t)^2 ## and the equation of mass's velocity in the y direction ( which is the derivative of the location of the particle in the y-direction w.r.t time )
where ## y_0 ## is the initial height ( it depends on where your coordinate system is placed ) , ## v_0 ## is the initial velocity in the y-direction , and ## a ## is the constant acceleration.
I won't tell you have to solve the problem, but some hints are here.
The mechanical energy is always constt. which is equal to KE +PE ,as the ball moves upward the KE decreases and the PE increases from the the base level.
So at the time of launch e.g at the base level PE is 0 if we take it to be reference level.
So the total mechanical energy is KE at the time of launch which remains constt
throughout it's motion.
See my previous post: It doesn't have enough kinetic energy to reach the height given in the problem statement. Something else has to be there.
OP didn't come back to clarify the problem statement, this might stay a mystery.
Oh that means the total energy (KE) at the time of launch is less than the total energy at heighest point.
Yes, that suggests there is some additional source of energy we don't know about. Does it keep its speed? Does something else happen?
I don't think it helps to speculate, we need a reply from OP, and as long as we don't have that we can just let the thread rest.
Related to Calculating Mechanical Energy of a Launched Ball
1. How do you calculate mechanical energy?
Mechanical energy is the sum of kinetic energy and potential energy in a system. To calculate it, you can use the equation E = KE + PE, where E is mechanical energy, KE is kinetic energy, and PE is potential energy.
2. What units are used to measure mechanical energy?
Mechanical energy is typically measured in joules (J), which is the standard unit of energy in the International System of Units (SI).
3. Can mechanical energy be negative?
Yes, mechanical energy can be negative. This happens when the potential energy is greater than the kinetic energy in a system, resulting in a negative value for mechanical energy.
4. How does friction affect mechanical energy?
Friction is a force that opposes motion and can convert some of the mechanical energy in a system into heat. This means that friction can cause a decrease in mechanical energy.
5. Is mechanical energy conserved in all situations?
In an ideal situation with no external forces acting on a system, mechanical energy is conserved. However, in real-world situations, external forces like friction and air resistance can cause a decrease in mechanical energy.
