b100c
- 6
Two identical brass bars in a chamber with perfect (thermally insulating) vacuum are at respective temperature T hot>T cold. They are brought in contact together so that they touch and make perfect diathermal contact and equilibrate towards a common temperature. We want to know what is the change of entropy to the whole system (cold plus hot bars) according to Boltzmann’s formula S=kln(Ω).
To study that problem, we will consider a simple model. We will assume that the hot bar consists of 4 atoms with 5 quanta of energies that can be distributed arbitrarily among the 4 atoms. For example, three atoms can have one quantum, one atom has two quanta, making a total of (3×1+1×2) quanta=5 quanta. This is one of the many microstates that this system can have with the constraint of 5 quanta in total.
We will assume that the (identical) cold right bar also has 4 atoms, but now with only 1 quantum of energy, as it is colder, that can be distributed arbitrarily among the 4 atoms.
1. Assuming that the atoms are distinguishable, compute the number of microstates initially (before they are brought in contact) for the cold bar.
2. Compute the number of microstates initially for the hot bar.
3. Once they are brought touching together, the energy equilibrates (so that the two bars reach a same/ common temperature). How many quanta of energy exist in the left bar? How many in the right bar?
4. Compute the entropy change for the left bar. Compute the entropy change for the right bar.
5. What is the total entropy change for the whole system? Has it increased or decreased?
S= kln(Ω)
1. Well the cold bar only has one macrostate, which is 1 atom with 1 quantum, and 3 atoms with 0. So this is asking how many permutations are there of 1-0-0-0.
To find the number of microstates (permutations), use the formula
[tex]\frac{N!}{{\prod\limits_{k}}M_k!}[/tex]
with 1 for M1, 3 for M2, and 4 for N. This gets the answer 4.
2. Here, I use the same formula from part 1 on the different macrostates, and get 56 microstates in total.
3. I would think that the quanta would even out so that there are 3 quanta in each bar right?
4. I'm confused with this part, I know I use S= kln(Ω), but is Ω the total number of microstates, or the number of microstates for the most likely macrostate?
5. The entropy change for the whole system should just be the sum of the two entropy changes, and I expect it to not decrease by the 2nd law of thermodynamics.
