mostafaelsan2005
- 71
- 3
- Homework Statement
- I am doing an experiment with the overall research question of: To what extent does the amount of fluid within a hollow cylindrical can affect its dynamics while rolling down an inclined plane
w I have been treating it as an inviscid fluid for the purpose of the derivations that I have made.
- Relevant Equations
- I have found the equations for how to represent acceleration for a solid and hollow cylinder along an inclined ramp assuming "pure roll" for now but I want to find an equation to represent different MOI's and perhaps hydrodynamic pressures?
I was able to derive an equation for acceleration for the case of a fully solid cylindrical shell and then used law of conservation of energy to determine equations for the velocity of a solid and hollow cylinder and I understand that the moment of inertia's of the aforementioned cans can also be found easily using the radius. However, I am finding difficulty in finding a method to determine the moment of inertia for cans that are partially filled other than the parallel axis theorem which I am not sure can be applied to this scenario. Furthermore, I am also unsure about the actual experiment that I am doing to answer the initial research question (I have access to a motion sensor and photogate sensor) and was wondering if I should simply measure the final velocities and relate it to varying moment of inertias if it is possible to calculate but would appreciate any alternatives to this experiment. Finally, I am not sure if I should treat the water as an inviscid fluid as that would mean there would be no effects on the moment of inertias but the mass would still change so that would affect it in that regard, right? For now I have been treating it as an inviscid fluid for the purpose of the derivations that I have made.
