Samuelriesterer
- 110
A speaker emitting sound at a frequency of 20 Hz is moving in the +x direction between two detectors. The speaker is moving at a speed of 30 m/s and the detectors are wired so that they flash red (λ = 700 nm) when the pressure is a maximum and green (λ = 700 nm) when the pressure is a minimum. Use 340 m/s as the speed of sound.
[1] Calculate the distance between maxima ahead and behind the moving speaker.
[2] Calculate the frequency of the light blinking on each of the detectors.
[3] An observer between the detectors is moving at 0.8c in the +x direction. Calculate the frequencies for the red and green lights for each detector this observer sees.
[4] Transform the velocity of the speaker to the observer frame as well as the velocity of sound in each direction.
2. Homework Equations
##f' = f \frac{v \pm v_{receiver}}{v \pm v_{source}}##
##t' = \frac{t}{\sqrt{1-\frac{v^2}{c^2}}}##
I am confused at the start with how the detectors detect maximum and minimum pressure and subsequently question1 about the maxima?
