jackrabbit
- 12
I am trying to figure out the net force of around a fulcrum (actually two fulcrums). For ease, assume the following hypothetical and ignore the weight of the beam itself in the calculations:
There is a beam that is 21 feet long that is being lifted by a crane. The left end is at "0 feet" and the right end is at "21 feet."
There are three points along the beam.
Point A: Located at 0 feet, with a downward force of 3 pounds.
Point B: Located at 14 feet. This is where the cable from the crane is attached to the beam. The cable is lifting with a force of 12 pounds.
Point C: Located at 21 feet, has a downward force of 8 pounds.
When the crane lifts the beam, the beam will rotate around Point B (meaning that Point C will not tilt toward the ground).
Now assume that, as the crane lifts the beam, the beam hits a branch at Point D, located at 7 feet. How do I determine which way (or whether) the beam will rotate around Point D?
