MHB Calculating Number of Sides in an n-gon with an Average Angle of 175°
  • Thread starter Thread starter blahblah
    Angle Average
To determine the number of sides (n) in a polygon with an average interior angle of 175 degrees, the formula for the average angle, \((n-2) \times 180^\circ / n\), can be applied. The discussion highlights that the polygon in question may not be regular or even convex, despite the average angle calculation typically applying to convex polygons. Participants express differing views on whether the term "average" indicates irregularity, with some suggesting it could be poorly worded. Ultimately, the average angle remains consistent regardless of the polygon's regularity. The conversation emphasizes the importance of clarity in mathematical terminology.
blahblah
The interior angles of an n-gon have an average measure of 175 degrees. Calculate n.
Mathematics news on Phys.org
Hi blahblah,
Welcome to MHB!
If you have a polygon with $n$ sides then each angle can be expressed as [math]\frac{(n-2) \times 180^\circ}{n}[/math]. Can you use this formula and the given information to solve for $n$?
Jameson
Jameson said:
Hi blahblah,
Welcome to MHB!
Jameson
The implication of the question is that the polygon is not necessarily regular (possibly not even convex) - though given the nature of the question the average of the interior angles of an n-gon is probably an invariant.
In fact it is trivial to show that your formula is the average interior angle for an arbitrary convex n-gon, so that is all-right then!
CB
CB
I don't see that but trust that you know this better than I do. From the level of the other thread the OP made here it seems more likely to me that this is a straightforward question, but I should consider irregular polygons in the future.
EDIT: Ah I think I see your point now. The word "average" could definite imply that the polygon isn't regular although I think it might just be badly worded.
I have often seen the word n-gon used to describe a regular polygon or isogon, i.e., a polygon with all sides and all angles equal.
However, when I saw the term "average measure" for the interior angles, I assumed then a convex polygon, not necessarily regular, as the same number of sides results either way.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
