MHB Calculating Power for a Study: Population µ = 100, σ = 20
The discussion focuses on calculating the power of a study with a population mean (µ) of 100 and standard deviation (σ) of 20, using a sample of 50 participants. The initial calculations incorrectly determined the power to be 57.53%, which was identified as the type II error (β). The correct power is 42.47%, calculated as 1 - β. A key point raised is the importance of distinguishing between areas in Z tables, specifically the need to reference the area to the right of the calculated z-value for power. Understanding this distinction is crucial for accurate statistical analysis in hypothesis testing.
TrielaM
I have had some issues with an equation in one of my classes, hoping some one can point out what I am going wrong. If anyone can point out some flaw in my process or calculations I would appreciate it. The problem lists:
Population µ = 100, σ = 20. Planning to have a sample of 50 participants, and expect the sample mean to be 5 points different from the population mean. Use non-directional hypothesis and α = .05.
What is the Power for this planned study?​
My calculations:
σ /(SqrRt)n = 20/(SqrRt) 50 = 20/7.071 = 2.828 Standard error
α = .05 = z = +1.96
1.96(2.828) = 5.543
z= (M-µ)/Standard Error = (105.543-105)/2.828 = .543/2.828 = 0.19
Z Table: .19 = .5753
Power = 57.53%
My calculations:
α = .05 = z = +1.96
1.96(2.828) = 5.543
Power = 57.53%
Welcome to MHB, TrielaM! :)
It appears you have calculated the type II error $\beta$.
The power is its complement.
In your case:
\begin{aligned}\beta &= 57.53\% \\
\text{Power} &= 42.47\% \end{aligned}
Thank you very much for the reply. So in the process I used I needed to add a step for 1-B. Would this step be applicable all the time with this form of equation or no? The books I was using didn't include this but it was certainly the correct answer, instead it had you pull from a Z table in the section for the body, where as here the answer was found in the tail. At least I know where I was flubbing up though I am still not sure how to make the distinction.
Yes.
I would suggest always drawing a picture though, like the one I have included in my previous post.
Apparently you pulled your result from a Z table that gives the area to the left, which is pretty standard and often shown in a small graph next to the table.
As a result your value of z=0.19 gives you the green area.
But you need the blue area, which is the area to the right of z=0.19.
Note that the power of a test (the blue area) is the probability that we reject the null hypothesis when it should indeed be rejected, because the alternative hypothesis is true.
I'm taking a look at intuitionistic propositional logic (IPL). Basically it exclude Double Negation Elimination (DNE) from the set of axiom schemas replacing it with Ex falso quodlibet: ⊥ → p for any proposition p (including both atomic and composite propositions). In IPL, for instance, the Law of Excluded Middle (LEM) p ∨ ¬p is no longer a theorem. My question: aside from the logic formal perspective, is IPL supposed to model/address some specific "kind of world" ? Thanks.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
