A p - V engine, or pressure-volume engine, is a type of internal combustion engine that converts chemical energy into mechanical energy by burning fuel inside a confined space.
A p - V engine works by using the pressure generated by the combustion of fuel to drive a piston, which in turn rotates a crankshaft to produce rotational motion. This motion is then used to power the vehicle or machinery.
The advantages of a p - V engine include high power output, high efficiency, and low emissions compared to other types of engines. They also have a simple design and are relatively easy to maintain.
One major disadvantage of a p - V engine is that it can only operate on a two-stroke cycle, which can lead to higher fuel consumption and more emissions. Additionally, p - V engines can be quite loud and produce a lot of vibration.
The power of a p - V engine is typically measured in horsepower (hp) or kilowatts (kW). This measurement is based on the amount of work the engine can perform in a given amount of time, usually one minute.
