Calculating pressure exerted by a cylinder
In summary, to calculate the pressure exerted by a 75kg solid cylinder standing on one end with a length of 2.1m and an end radius of 5.0cm, you can use the equation P = F/A, where F is the downward force (obtained from the given mass and acceleration due to gravity) and A is the area of the circular end of the cylinder. Adjustments for buoyancy should only be made if the cylinder is in air or a vacuum, which is not specified in this problem. The resulting pressure will be a large number expressed in Newtons per square metre.
connorm710
A 75 kg solid cylinder, 2.1 m long and has an end radius of 5.0 cm, stands on one end. How much pressure does it exert?
P = f/a
P= pwh (this is the equation my teacher gave us on a power point but I might just be using it wrong)
v = pi r2h[/B]
v = .052 pi 2.1
v = .016 m3
density = 75 / .016
density = 4687.5[/B]
weight = 75 x 9.8
weight - 735
P = 735 x 4687.5 x 9.8
P = 33764062.5
I feel like that number is way to big and I am doing more work than is needed. Thanks in advance!
Yes you do appear to be doing more work than needed. From your first equation P = F/A you can see that you only need the downward force and the area. The force is obtained directly from the given 75kg mass and the acceleration due to gravity, via F=ma. The area A is simply the area of the circular end of the cylinder.
The only reason to use the volume of the cylinder would be if you were to make an adjustment for the buoyancy of the cylinder in air. But since we do not know if the cylinder is in air (and at what air pressure) or in a vacuum, we cannot make that adjustment.
It will still be a big number, as it is expressed in Newtons per square metre and Newtons are small while square metres are big. But it won't be quite as big as the number you got.
Related to Calculating pressure exerted by a cylinder
1. How do you calculate the pressure exerted by a cylinder?
To calculate the pressure exerted by a cylinder, you will need to know the force and the area of the cylinder's base. The formula for pressure is force divided by area, or P = F/A. This will give you the pressure in units of force per unit area, such as pounds per square inch (psi) or Newtons per square meter (N/m^2).
2. What is the formula for calculating the force of a cylinder?
The force of a cylinder is equal to the pressure multiplied by the area. So, the formula for force is F = P x A. Make sure the units for pressure and area are consistent for accurate calculation.
3. Can you give an example of calculating pressure exerted by a cylinder?
Sure, let's say we have a cylinder with a force of 1000 newtons and an area of 2 square meters. Using the formula P = F/A, the pressure exerted by the cylinder would be 500 newtons per square meter or 500 N/m^2.
4. How does the height of a cylinder affect the pressure it exerts?
The height of a cylinder does not directly affect the pressure it exerts. Pressure is dependent on the force and area of the cylinder, not its height. However, the height may indirectly affect the pressure if it changes the weight or force being applied to the cylinder.
5. Can pressure exerted by a cylinder be negative?
Yes, the pressure exerted by a cylinder can be negative. This would indicate that the force is acting in the opposite direction of the area, or that the cylinder is experiencing a negative pressure or suction. For example, a vacuum pump creates negative pressure in a cylinder to remove air or fluid.
