Calculating pressure of air pocket in a pressurized water column
To calculate the pressure of the air pocket in a pressurized water column, it's essential to clarify the setup: a 2-inch vertical pipe, capped, containing 2 inches of air at the top and 40 psi of water at the bottom. The pressure measurement of 40 psi is taken at the bottom of the 24-inch tall pipe. As the water rises, the pressure decreases due to the height of the water column. The pressure drop can be calculated using hydrostatic pressure principles, factoring in the height of the water column and the density of the water. Understanding these elements will provide clarity on the pressure dynamics within the system.
cvsanders
TL;DR Summary
Calculating pressure of air pocket in pressurized water column.
Looking for some guidance in calculating pressure of air pocket in pressurized water column. Example: 2" vertical pipe, capped, with 2" of air and 40 psi water applied.
Welcome to PF. :smile:
Presumably the air bubble is at the top of the column, right? Where are you measuring the 40psi water pressure? At the top or bottom of the water column? How tall is the pipe?
Water supply line pressure is 40 psi, air is at top of 24" column, where it is being read.
So the 24" tall pipe has 40psi water at the bottom. How much does the pressure drop going up that water column...? :smile:
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
