MHB Calculating Probability of Choosing 11 Reds in a Row
  • Thread starter Thread starter resolution12meh
    Probability Row
The probability of picking 11 red socks in a row from a drawer of 100 socks (84 red and 16 white) is calculated as P1 = 84!/73! * 89!/100!. Conversely, the probability of picking 10 white socks and 1 red sock is P2 = (16!/6!) * (90!/100!) * (84/90) * 11. The calculated probabilities yield P1 ≈ 0.131 and P2 ≈ 4.75e-9, indicating that the odds of picking 11 reds in a row are significantly higher than picking 10 whites and 1 red, with a ratio of approximately 27,612,527 to 1. This outcome aligns logically with the higher quantity of red socks available.
resolution12meh
I realize this is probably quite easy and basic but I just can't get comfortable with calculators to work it our with any certainty.
There are 100 socks in a drawer. 84 are Red. 16 are White. If you are blindfolded & have to choose 11 socks randomly, what is the odds or what it more likely:
1) Picking 11 reds in a row.
OR
2) Picking 10 whites and 1 redI know the answer is 2, but just need the correct calculation, math and percentage behind each option.
Thanks in advance.
Mathematics news on Phys.org
Why are you not able to do this yourself? As your title says, this is pretty basic!
There are 100 socks, 84 red. The probability the first sock chosen is red is 84/100. There are then 99 socks, 83 red. The probability the second sock chosen is red is 83/99.
There are then 98 socks, 82 red. The probability the third sock chosen is red is 82/98.
Get the idea? The probability that 11 red socks in a row are red is \frac{84(83)(82)\cdot\cdot\cdot (75)(74)}{100(99)(98)\cdot\cdot\cdot (91)(90)}.
We can write 84(83)(82)\cdot\cdot\cdot(75)(74) as \frac{84(83)(82)\cdot\cdot\cdot (3)(2)(1)}{73(72)\cdot\cdot\cdot(3)(2)(1)}= \frac{84!}{73!} and write 100(99)(98)\cdot\cdot\cdot (91)(90) as \frac{100!}{89!} so that answer can be written in the shorter form \frac{84!}{73!}\frac{89!}{100!}.10 white and one red sock can be done similarly. There are 100 socks and 16 white socks. The probability the first sock chosen is white is 16/100. There are then 99 socks, 15 of them white. The probability the second sock chosen is white is 15/99. Continuing in that way, the probability the first 10 socks chosen are white is \frac{16}{100}\frac{15}{99}\cdot\cdot\cdot\frac{7}{91}= \frac{16!}{6!}\frac{100!}{90!}. There are then 89 socks left, 84 of them red. The probability the last sock chosen is red is \frac{84}{89}. The probability the first 10 socks chosen are white and the last sock chosen is red is
<span style="font-family: 'Verdana'">\frac{16!}{6!}\frac{100!}{90!}\frac{84}{89}</span>.
That is the probability the first ten socks chosen are white and the last one red. A little thought should show that the probability "the first sock is red and the last 10 white" is exactly the same just with the fraction \frac{84}{89} at the front instead of at the back. And, in fact, the red sock being chosen at any place among the 10 white is exactly the same calculation, just with the fraction \frac{84}{89} in a different position among the white sock fractions.
So to find the probability of "10 white one red" in any order, we need to multiply that fraction by 10:
10<span style="font-family: 'Verdana'">\frac{16!}{6!}\frac{100!}{90!}\frac{84}{89}</span>.
I will leave it to you to actually multiply those (do a lot of cancelling first!).
Thank you for the answer and its really appreciated. Unfortunately, as good with numbers financially as i am, the math behind your answer is complicated to me and I am not 100% sure on working it out unfortunately. :-(
I would be super appreciative if someone could state in simple terms the 1 in x chance or the %age chance for each probability.
Thank you in advance anyone.
HallsofIvy's explanation is correct but there are some mistakes in formulas. So, for the first case (picking 11 reds in a row) the probability is:
${P}_{1} = \frac{84!}{73!}\frac{89!}{100!}$
For the second case (picking 10 white and one red sock) using the same reasoning we get the probability of choosing 10 whites in a row:
$\frac{16!}{6!}\frac{90!}{100!}$
and because the probability the 11-th sock then chosen is red is 84/90 and also because it can be chosen before or after or in between of 10 red socks this probability must be multiplied by 11. So, as a result we have the following probability for the second case:
${P}_{2} = \frac{16!}{6!}\frac{90!}{100!}\frac{84}{90} \cdot 11$
Using a simple online factorial calculator we can get:
${P}_{1} = 0.131$, ${P}_{2} = 4.75e-9$
So the odds in favor of the first case are:
${P}_{1} / {P}_{2} = 27612527 / 1$
that is absolutely logical because there are much more red socks than white ones.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
