Calculating Probability with Binomial Distribution
  • MHB
  • Thread starter karush
In summary: X-N(15,9) and from N(\mu,\sigma^2) looks like \sigma is 3If your course is using N(\mu,\sigma^2), which is also on wiki, that is is correct.However, if your course is using N(\mu,\sigma), it becomes a different matter.Can you tell from your course notes?From the given information, it seems like the course is using N(\mu,\sigma^2) notation. If that is the case, then your calculation is correct.For (b), you would do the same thing but look for the upper tail probability for z=2/3. So it would be 1-0.
karush
MHB
3,269
not sure what this means
If \(\displaystyle X \sim B(8,0.3)\), find \(\displaystyle P(X=5)\)
looks like we working off of a probability distribution table
Mathematics news on Phys.org
Yes, $\displaystyle X \sim B(8,0.3)$ simply means $X$ is a random variable following the distribution $B(8,0.3)$ ;)
In general $X \sim B (\mu,\sigma)$ means that X is distributed according to the 'B' distribution law with mean $\mu$ and variance $\sigma$. If 'B' means 'Binomial' then is...
$\displaystyle P \{X= x\} = \binom{n}{k} p^{k}\ (1-p)^{n-k}\ k=0,1,...,n\ (1)$
... and is...
$\mu = n\ p$
$\sigma= n\ p\ (1-p)\ (2)$
The problem is that if is $\mu=8$ and $\sigma = .3$ is doesn't exist any combination of n and p satisfying (2) so that may be that 'B' doesn't mean 'Binomial' in this case...
Kind regards
$\chi$ $\sigma$
Re: notation question
MarkFL said:
This is not an area in which I am very knowledgeable, but I would say that the notation:
\(\displaystyle B(n,p)\)
implies:
\(\displaystyle P(X=k)={n \choose k}p^k(1-p)^{n-k}\)
let me try this if \(\displaystyle X \sim B(8,0.3) \) and \(\displaystyle P(X=5)\)
then plug in would be
\(\displaystyle {8 \choose 5}0.3^5(1-0.3)^{1-0.3}=0.047\)
... and is...
$\mu = n\ p$
Kind regards
$\chi$ $\sigma$
well, the next problem is \(\displaystyle X \sim N(15,9)\), find \(\displaystyle P(X < 16)\) so assume B and N are just function names.
Yes, I get:
\(\displaystyle P(X=5)={8 \choose 5}\left(\frac{3}{10} \right)^5\left(\frac{7}{10} \right)^3=\frac{583443}{12500000}\approx0.04667544\)
The normal distribution can be denoted by $N\left(\mu,\sigma^2 \right)$.
Do you know how to standardize the data and use your table to find $P(x<16)$?
no but assume the first step is solve for just \(\displaystyle x=16\)
thanks for all your help btw...
Standardizing the data means calculating the so called $z$-value.
$$z=\frac{\text{boundary value of x} - \mu}{\sigma}$$
You can look up that value in a table of the standard normal distribution.
Do you have such a table?
this is what was given:
If \(\displaystyle X \sim N (15,9),\) Find
a) \(\displaystyle P(X < 16)\)
b) \(\displaystyle P(X \geq 17)\)
c) \(\displaystyle P(14 \leq X \leq 15.5)\)
d) \(\displaystyle P(X > 6)\)
e) \(\displaystyle P(X>k)=0.34\), then \(\displaystyle k=?\)
so from \(\displaystyle N\left(\mu,\sigma^2 \right)\) and \(\displaystyle N (15,9)\)
\(\displaystyle z=\frac{\text{boundary value of x} - 15}{3}\)
so how do we get boundary value of x?
Let's start with:
For (a) the boundary value of x is 16.
So \(\displaystyle z = \frac{16 - 15}{3} = \frac 1 3\).
Btw, I'm assuming your $\sigma^2=9$. There is a little ambiguity here, since it's also possible that your $\sigma=9$, which would of course give different results.
For instance from the wiki z-table, we can find that the corresponding lower tail probability is approximately 0.6293.
I like Serena said:
Let's start with:
from the given \(\displaystyle X-N(15,9)\) and from \(\displaystyle N(\mu,\sigma^2)\) looks like \(\displaystyle \sigma\) is \(\displaystyle 3\)let me try the next one
so \(\displaystyle z = \frac{17 - 15}{3} = \frac {2}{3} \approx .6667\)
so from z table \(\displaystyle .7454\)
If your course is using \(\displaystyle N(\mu,\sigma^2)\), which is also on wiki, that is is correct.
However, if your course is using \(\displaystyle N(\mu,\sigma)\), it becomes a different matter.
Close.
However, in (a) we were talking about the lower tail probability.
In (b) we're talking about the upper tail probability.
The z-table you used gives the lower tail probability (see the graph next to it).
But you can calculate the upper tail probability by taking 1 minus the lower tail probability.
OK but, I am not taking a course in this nor do I have a text or notes just trying to do a work sheet from a "summer 2014 math SL IB Questions" will be studying the subject more formerly this fall just want to get head start on it.
I like Serena said:
Close.
so for b) \(\displaystyle 1-.7454 = .2546\) are you referring to the bell shaped graph
for c) we have \(\displaystyle P(14 \leq X \leq 15.5)\)
\(\displaystyle z_u = \frac{14 - 15}{3} = - \frac {1}{3} \approx -.3334\)
I presume this is upper since \(\displaystyle 14 \leq X\)
from z table \(\displaystyle -0.6293\) however this was from a neg number
and \(\displaystyle z_l=\frac{15.5 - 15}{3} = \frac {.5}{3} \approx .16667\)
from z table \(\displaystyle 0.5636\)
so \(\displaystyle -0.6293 \leq X \leq 0.5636 \)
this was a shot in the dark...
so the last 2 questions
If \(\displaystyle X \sim N(15,9)\) find
\(\displaystyle
z_u = \frac{6 - 15}{3} = 3\)
z table \(\displaystyle = 0.9987\)
\(\displaystyle \frac{k-15}{3}=0.34\) then \(\displaystyle k=16.02\)
d) Correct.
e) Because 0.34 < 0.5, we know $k>\mu$. We want to find the $z$-score associated with an area of $0.5-0.34=0.16$. Once you find this $z$-score, add this many standard deviations to the mean:
\(\displaystyle k=\mu+z_k\sigma\)
What do you find?
MarkFL said:
d) Correct.
What do you find?
where does the \(\displaystyle 0.5\) come from?
like this?
\(\displaystyle k=15+0.8554(3)=17.5662 \)
Please refer to the following diagram:
We know the red area plus the green area is $0.5$. We want the green area to be $0.34$, thus the red area must be $0.5-0.34=0.16$.
What $z$-score is associated with an area of 0.16?
from the Cumulative from mean (0 to Z) table I find \(\displaystyle 0.06356\)
You are finding the area associated with $z=0.16$. You want to use the table the other way around. (Happy)
Good! And yes.
You're getting there...
You found that $P(X < 14) \approx -0.6293$ and that $P(X \leq 15.5) \approx .16667$.
Both are lower tail probabilities and you actually want the area in between in the bell curve.
To get it, you can simply subtract them from each other, effectively removing the lower tail from the leftmost one from the lower tail of the rightmost one.
That is, $P(14 \leq X \leq 15.5) = P(X \leq 15.5) - P(X < 14) \approx .1667 - -0.6293 = 0.7960$.
\(\displaystyle 0.15910\) is \(\displaystyle z=.41\) at least if you mean by the other way around...
Yes, if you want a bit more accuracy, I found:
\(\displaystyle z_k\approx0.412463129441\)
so then \(\displaystyle k=15+(0.412463129441)(3)=16.2374\) or round down to \(\displaystyle 16\) since has been in integers
I would round to the hundredths since the probability is given to this many places.
ok \(\displaystyle 16.24\)
thanks for all help I learned a lot...:)
FAQ: Calculating Probability with Binomial Distribution
What is -aux.12.Notation question?
-aux.12.Notation question is a way of representing scientific notation, where the number is expressed as a decimal number multiplied by a power of 10. The -aux.12 represents the power of 10, and the notation is used to make large or small numbers more manageable to work with.
How do you convert a number into -aux.12.Notation question?
To convert a number into -aux.12.Notation question, you need to move the decimal point to the left or right until there is only one non-zero digit to the left of the decimal point. The number of places you move the decimal point will be the power of 10 represented by the -aux.12.
How do you perform calculations with numbers in -aux.12.Notation question?
To perform calculations with numbers in -aux.12.Notation question, you must first convert all numbers into standard notation. Then you can perform the calculation as usual. Afterward, you can convert the result back into -aux.12.Notation question if desired.
Can -aux.12.Notation question be used for both large and small numbers?
Yes, -aux.12.Notation question can be used for both large and small numbers. It is a flexible notation that allows for easy representation of numbers that are too big or too small to be expressed in standard notation.
What are the advantages of using -aux.12.Notation question?
One of the main advantages of using -aux.12.Notation question is that it helps make very large or small numbers more manageable to work with. It also allows for easy comparison between numbers that have different powers of 10. Additionally, it is a widely recognized notation used in many fields of science.
