Calculating Projectile Velocity with Spring Compression
In summary, if you are trying to fire a projectile that has a spring constant of 50 N/m and you compress the spring 18 cm before it locks, the velocity of the ball as it leaves the launcher will be 4.13 m/s.
BlueDevil14
I have attempted to solve this problem repeatedly, but I cannot get a correct answer. Any help would be wonderful.
The Problem
A certain kind of projectile launcher has a spring constant of 50 N/m and you compress the spring 18 cm before it locks. When compressed, the spring is 2 cm tall. The piston and spring each weigh 50 g and the ball weighs 10 g. If you launch the ball vertically, what do you expect the velocity of the ball to be as it leaves the launcher? Don't forget the gravitational potential energy gained as each object's center of mass moves vertically.
The correct answer is 4.13 m/s
My attempt at a solution
Potential energy at full compression must equal kinetic energy minus gravitational potential energy at the point when the ball is released
At full compression: U = 1/2*k*d^2 - m*g*h1 where d is displacement
At release: K=.5*M*v^2 where M is effective mass (.077 kg)
U=-m*g*h2
Therefore: 1/2*k*d^2 - m*g*h1=.5*M*v^2-m*g*h2
or 1/2*k*d^2 + m*g*(h2-h1)=.5*M*v^2
I just keep getting 4.65. I cannot figure out what minor mistake I am making. Its killing me though.
Try starting with the gravitational potential energy zero reference set at the spring's compressed state. When the spring is released and reaches its relaxed position, the KE available will be the difference between the stored spring energy and the energy 'sapped' by the various masses rising to the relaxed position.
Call the stored spring energy PS, the change in gravitation potential energy PE, the kinetic energies KS, KP, and KB for the spring, piston, and ball. Then
PS - PE = KS + KP + KB
Can you write expressions for each of the energies?
KS= 1/2 m_s *v^2 where m_s=effective mass of the spring (.017 kg)
KP= 1/2 m_p *v^2 where m_p=mass of piston (.050 kg)
KB= 1/2 m_b *v^2 where m_b=mass of ball (.010 kg)
PS= 1/2 k*d^2 where k=constant (50 N/m), d=displacement (.18 m)
PE= 9.81*d*m_all where m_all= m_s+m_p+m_b
when solving now I get 4.20 m/s
Am I correct in using effective mass for PE?
While the ball and piston rise 18cm, the center of mass of the spring will rise less (check the positions if its center of mass before and after).
Use the actual mass of the spring when working out its change in PE, since you'll be working with the change in height of its center of mass.
I changed my PE to reflect center of mass so it is now:
[9.18*.18*(mP+mB)]+[9.8*.09*(.050)]
so v= 4.15 REALLY close to the correct answer
Well, to my eye it looks like your calculations are good (I assume that the "9.18*" in your PE expression is a typo for "9.8").
I can't think of anything that's missing, unless the relaxed position of the spring is taken to be with only the mass of the piston (imagine the spring being compressed 18cm from the rest position with just the mass of the piston resting on it, being latched in position, then the ball is placed on top). This would produce a slightly lower 'relaxed' height for the combined mass.
Yes, the 9.18 is a typo for 9.81
Thanks for the help, I think I understand the concepts.
Related to Calculating Projectile Velocity with Spring Compression
1. What is work and energy in a spring?
Work and energy in a spring refer to the physical concepts of work and energy as they relate to a spring system. Work is defined as the force applied to an object multiplied by the distance over which it is applied, and energy is the ability to do work. In a spring system, work is done to compress or stretch the spring, resulting in potential energy being stored in the spring. This stored potential energy can then be converted into kinetic energy as the spring returns to its original position.
2. How is the amount of work done by a spring calculated?
The amount of work done by a spring can be calculated using the formula W = 1/2kx^2, where W is the work done, k is the spring constant, and x is the displacement of the spring from its equilibrium position. This formula is derived from the concept of work as the product of force and distance.
3. What is the relationship between the spring constant and the amount of potential energy stored in a spring?
The spring constant is a measure of the stiffness of a spring and is directly proportional to the amount of potential energy stored in the spring. This means that as the spring constant increases, the amount of potential energy stored in the spring also increases.
4. How does the mass of an object affect the work and energy in a spring system?
The mass of an object does not directly affect the work and energy in a spring system, as it is not a factor in the equations used to calculate these values. However, the mass of an object can affect the displacement of the spring and therefore indirectly impact the amount of work and energy involved in the system.
5. Can the work done by a spring be negative?
Yes, the work done by a spring can be negative if the displacement of the spring is in the opposite direction of the applied force. This means that the force is doing work on the spring instead of the spring doing work on the object. Negative work can also occur if the spring is over-compressed or over-stretched, causing the potential energy to decrease.
