Calculating Pulley and Shaft Loads for an Existing System
In summary, the conversation focused on a pulley/shaft check for an existing system. The pulley had a diameter of 840mm and the motor had a breakdown torque of 47kw and 390 nm. To find the force from the belt, the force at the pulley o.d. distance can be assumed. The torque at that distance can be calculated by multiplying the force and the pulley radius. The conversation also discussed the need to check the adequacy of the shaft to pulley locking device and how to calculate the load torque through the locking device. It was determined that the locking device torque will be the same as the pulley torque. The conversation also addressed the importance of knowing the radius of the locking surface and
Stephen123
Hi, i need to do a pulley/shaft check on an existing system.
Pulley is 840mm diameter and the motor has 47kw and 390 nm breakdown torque so to find the force from the belt can i assume that the force at the pulley o.d. distance is the force? So 390*0.84 will give the torque at that distance?
I also need to check that the shaft to pulley locking device is adequate. I have the rated Nm of the locking device but how do i find the load torque through the locking device?
Thanks.
For pulley torque or force, the pulley radius is needed, not the pulley diameter.
Force at pulley radius is 390 Nm / 0.42 m = 930 N.
You should not need to know the locking device or shaft diameter. The locking device torque will be the same as the pulley torque.
When you say the locking device torque will be the same as the pulley torque, what do you mean by pulley torque? The locking device locks the shaft to the pulley and is rated for 12,000Nm of torque. How can i actually find what the torque at the locking device is?
Thanks
Torque is independent of radius until you need to convert it to a linear force.
Tangential (force in Newtons) * (radius in metres) = (torque in Newton∙metres), Nm.
The tension in the belt measured in Newton, N, multiplied by the radius of the pulley, is the pulley torque. Since all parts are connected together the pulley torque, shaft torque and the locking device torque are all the same.
To work out the tangential force at the locking device you need the radius of the locking surface, but that is NOT needed in your example.
The 390 Nm breakdown torque is significantly less than the lock rating of 12 kNm so there should be no problem.
Tangential (force in Newtons) * (radius in metres) = (torque in Newton∙metres), Nm.The tension in the belt measured in Newton, N, multiplied by the radius of the pulley, is the pulley torque. Since all parts are connected together the pulley torque, shaft torque and the locking device torque are all the same.
I understand what you mean now Baluncore, that makes sense. Thank you for the help!
In case it matters...belts are pre-tensioned. The force calculated above is the difference in tension between the two sides of the belt.
Likes Swapnil Karale
FAQ: Calculating Pulley and Shaft Loads for an Existing System
1. What is a pulley/shaft calculation?
A pulley/shaft calculation is a mathematical process used to determine the appropriate size and dimensions of a pulley and shaft system for a given application. It takes into account various factors such as load, speed, and torque to ensure the system is able to function properly and efficiently.
2. Why is a pulley/shaft calculation important?
A pulley/shaft calculation is important because it ensures that the pulley and shaft system is able to handle the required load and operate at the desired speed without experiencing failures or breakdowns. It also helps in selecting the most cost-effective and efficient system for a particular application.
3. What are the key components of a pulley/shaft calculation?
The key components of a pulley/shaft calculation include load requirements, speed requirements, torque requirements, pulley size and dimensions, shaft size and dimensions, and material selection. Other factors such as safety, cost, and environmental conditions may also be considered.
4. How do you perform a pulley/shaft calculation?
To perform a pulley/shaft calculation, you first need to gather all the necessary information such as load, speed, torque, and other requirements. Then, using mathematical formulas and equations, you can determine the appropriate sizes and dimensions of the pulley and shaft. There are also online calculators and software programs available that can assist with the calculation process.
5. What are some common mistakes to avoid when performing a pulley/shaft calculation?
Some common mistakes to avoid when performing a pulley/shaft calculation include using incorrect or outdated equations, not considering all the necessary factors, and underestimating the load or speed requirements. It is important to double-check all calculations and consult with experts if needed to ensure an accurate and reliable result.
