Calculating rate of fall of a sewer branch line
  • Thread starter Thread starter sevensages
    Branch Rate
The discussion revolves around calculating the rate of fall for a sewer branch line, where the correct answer is stated to be 1.5 inches per foot of run, despite the user's calculations suggesting 1/18, or approximately 0.667 inches per foot. The user expresses confusion about how to mathematically arrive at 1.5 inches per foot given the parameters of a 36-foot run and a 2-foot elevation difference. There is speculation that the question may contain an error, as the user believes the correct answer should align with their calculations. Participants suggest reaching out to an instructor for clarification and note that textbook errors can occur, complicating the learning process.
sevensages
The length of run for a sewer branch line is 36 feet. The difference of elevation is 2 feet. Based on these dimensions, calculate the rate of fall.
Rate of fall = difference in elevation/length of run
I am enrolled in a online plumbing course with Stratford Career Institute. This question was on my exam. This question is a multiple choice question. The possible answers are the following: 1/4" per foot of run, 2 inches per foot of run, 1/2 inch per foot of run, and 1.5 inches per foot of run. I answered 1/2 inch per foot of run. So I got this wrong. Stratford Career Institute says that the correct answer is 1.5 inches per foot of run. I don't understand how to get to the correct answer mathematically.
I will put the question on my exam in green font. Here is the question on my exam: The length of run for a sewer branch line is 36 feet. The difference of elevation is 2 feet. Based on these dimensions, calculate the rate of fall.
Using the textbook, I know that the relevant equation for this question is the following:
So I know that the Rate of fall = 2'0"/36'
rate of fall = 1/18--------------------------
Here is the part that baffles me. How do you get from 1/18 to 1.5 inches per foot of run mathematically?
When I was taking the test, I dismissed the answer of 1.5 inches per foot of run because it seemed to me that 1.5 inches per foot of run would be 54 inches. 1.5 inches per foot of run multiplied by 36 feet of run is 54 inches. 54 inches is 4'6". The exam question said that the difference of elevation is 2 feet, not 4'6".
Again, how do you get from 1/18 to 1.5 inches per foot of run? I am baffled. I need someone to show me the answer to this mathematically rather than only explaining it to me with words.
I agree that 1/18 should be the answer, and I don't see how the listed choices could work. 1/18 is .667"/foot...
In the section of your textbook or other learning resource that discusses rate of fall like this, do all of the examples make sense?
  • Agree
Likes Beyond3D and sevensages
Yes.
Okay, good. Can you ping your instructor/TA to ask about this? Please let us know what they say.
I get the same. As some of the answers are given in units of inch/feet, another possible answer would be ##\frac 2 3 \frac{\text{inch}}{\text{ft}}##. Since one of the given possible answers is ##1.5 \frac{\text{inch}}{\text{ft}}##, it seems possible to me that whoever created the question got the division wrong, using the reciprocal of 1.5.
Likes berkeman, Tom.G and sevensages
Sometimes textbook creators make errors in the books. For example in my shaum's trig textbook the answer key was off by a large amount in "seconds" (the degree listed as ##\theta^{\circ}\theta'\theta''##).
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
