Calculating relative velocity -- Jumping between two moving trains
In summary, calculating relative velocity involves understanding the motion of two objects in relation to each other. When considering two moving trains, the relative velocity of one train as observed from the other can be determined by subtracting the velocity of one train from the other. If both trains are moving in the same direction, the relative velocity is the difference between their speeds. If they are moving towards each other, the relative velocity is the sum of their speeds. This concept is crucial for analyzing scenarios like jumping between trains, where the jumper must account for the relative motion to ensure a successful landing.
verkamp
two trains running parallel, same velocity. what happens if I jump from one train to another?
Vba = Vb - Va
is it possible?
I've given it quite some thought, and my conclusion was that it would be possible, cuz right after I jump, I'll still have the same velocity in the same direction as the running train?
verkamp said:
Homework Statement: two trains running parallel, same velocity. what happens if I jump from one train to another?
Relevant Equations: Vba = Vb - Va
is it possible?
You will have the same velocity but there will be a wind blowing you back at the same velocity. You cannot ignore air resistance in this case, so don't try it.
Track separation (center to center) in the U.S. is generally 14 feet minimum (source Michigan DOT department of rail). Passenger rail cars are a bit under 10 feet side to side (source various). So that is about 4.5 feet of train to train gap measured from toe of jumping foot to heel of landing foot. Doable, but not supremely safe.
Watch out for signal posts.
Likes nasu and PeroK
Looks like this experiment has been carried out, at least once...
  • Haha
Likes jbriggs444 and kuruman
