Calculating required horsepower
  • Thread starter samjverm
  • Tags
    Horsepower
In summary: Furthermore, the problem statement does not make it clear what "force" is being exerted upon the car--either the car's own weight, or something else. Without knowing more about the problem, it is difficult to provide a definitive answer.
samjverm
Calculate the horsepower required to move a 2000 lb. car half a mile in 6 seconds.
1 hp = 550 ft lb / sec
work = distance (ft) * force (lbs)
hp = (distance(ft) * weight(lbs)) / 550(ft lbs/sec)
power = work / time
My attempt at the solution goes as follows:
power = work / time
power = (distance * force) / time
power = (2640 ft * 2000 lb) / 6 seconds = 880000 ft lb / sec
horsepower = 880000 ft lb/sec / 550 ft lb/sec = 1600 hp
however i do not know if this is correct
Bystander said:
im sorry this had not helped me, i have no education in physics or math. if you could explain a little more that would be appreciated.
samjverm said:
Homework Statement: Calculate the horsepower required to move a 2000 lb. car half a mile in 6 seconds.
Homework Equations: 1 hp = 550 ft lb / sec
power = work / time
"Pound-mass" does not equal "pound-force;" can you identify the difference between the two units from the discussion in the article?
I think the statement uses ##lb## but it actually means ##lbf## since the units for ##1hp## are also given in terms of ##lb##.
Other than that if find the statement a bit vague... What is the force we are pushing against? Is it the car's weight or something else? Also is the speed during the push supposed to be constant?
Delta2 said:
Also is the speed [insert]acceleration(?)[/insert] during the push supposed to be constant?
I'm treating it as a double drag race (two quarters equal a half) at constant acceleration.
That formula computes the energy required to accelerate the car at one gee over a distance of 2640 feet. It then divides by the six second elapsed time to get average power.
One problem is that we have no idea whether one gee is sufficient to move the car 2640 feet in 6 seconds. But we can check for that...
Suppose that the car accelerates at one gee (32 feet per second per second) for a duration of six seconds. Its speed at the end of those six seconds will be 32 * 6 = 192 feet per second. Its average speed will be half that, 96 feet per second. Multiply average speed times duration to get 96 * 6 = 576 feet. Far short of the required half mile.
You will need more than one gee of acceleration to finish the race in six seconds.
Given your level of education, we may not want to tackle a completely correct approach. We should probably assume constant acceleration and work toward determining what final speed is required as a first step.
Constant acceleration is not constant power. It's actually a much more interesting question if you assume constant power. Kinetic energy is ##E = \frac{1}{2} m V^2## so the power is ## \frac{dE}{dt} = m V \frac{dV}{dt} = m V a = K## a constant. That equation might be solvable by a high-school student that has had intro calculus.
Likes jbriggs444
Delta2 said:
Other than that I find the statement a bit vague...
Vague problem statements are often due to the original Poster paraphrasing the problem, and leaving out important bits without realizing. It would be best for the OP to provide the actual question/problem, word-for-word. Then we can help by showing what the important parts mean.
The OP's proposed solution is clearly heading towards the power required to hoist the car to an elevation of 1/2 mile in the given time; it is highly unlikely that this is what the problem was really about, since that really has nothing to do with a "car."
Likes Delta2
FAQ: Calculating required horsepower
1. How do you calculate required horsepower for a specific application?
To calculate required horsepower, you need to know the weight of the object or material being moved, the distance it needs to be moved, and the time it takes to move it. You also need to know the force required to move the object, which can be determined by considering factors such as friction and acceleration.
2. What units are used to express horsepower?
Horsepower is typically expressed in units of horsepower (hp) or kilowatts (kW). One horsepower is equal to 0.7457 kilowatts.
3. How does the speed of the object being moved affect the required horsepower?
The speed of the object being moved can affect the required horsepower in two ways. First, the faster the object needs to be moved, the more power is required to overcome the resistance and friction. Second, if the object is being moved over a longer distance, more power is required to maintain the speed over that distance.
4. Can the type of motor or engine affect the required horsepower?
Yes, the type of motor or engine can affect the required horsepower. Different types of motors or engines have different power output capabilities, and the efficiency of the motor can also play a role in the required horsepower. For example, an electric motor may require less horsepower than a gasoline engine to achieve the same level of force.
5. How do you factor in the efficiency of the motor or engine when calculating required horsepower?
To factor in the efficiency of the motor or engine, you can use a formula that takes into account the power input and output of the motor. This formula will give you the efficiency percentage, which you can then use to adjust the required horsepower calculation. It's important to consider the efficiency of the motor or engine to ensure that you are using the most accurate and efficient power source for your application.
13K
