MHB Calculating Scale on a School Map
  • Thread starter Thread starter Baylee1014
    Map Scale School
To calculate the scale on a school map where 3 inches represents 9 feet, the problem can be set up as a proportion. Specifically, the equation is x inches to 1.5 feet as 3 inches to 9 feet. Solving this gives x = 0.5 inches, but it’s important to note that x must be smaller than 3 inches since 1.5 feet is less than 9 feet. Thus, the correct representation of 1 foot 6 inches on the map is 1.5 inches. Understanding these proportions is crucial for accurate mapping.
Baylee1014
Not sure if this is the right category but i need help.
On a map of a school, 3 inches represents 9 feet. How many inches would represent 1 foot 6 inches?
Mathematics news on Phys.org
Hello Baylee1014,
Yes, you have chosen the correct sub-forum in which to post your question. (Yes)
It is best though to show what you've tried or what your thoughts are on how to begin so our helpers know exactly where you're stuck or need help.
The problem is essentially stating:
$x$ inches is to 1.5 ft as 3 inches is to 9 ft.
Can you translate that into an equation which you can then solve for $x$?
MarkFL said:
Hello Baylee1014,
x is equal to .5 so would it would 18 inches??
Yes, good work...you are right that $$x=\frac{1}{2}$$, but $x$ is in inches, not in feet.
You should know too that $x$ must be smaller than 3 inches because 1.5 is less than 9.
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
20K
