Calculating second ionization energy of He
In summary: ENERGYIn summary, the equation En=-Z2RH/n2 gives the energy (according to the Bohr model) of the energy levels available to an electron in any hydrogen-like atom. The second ionization energy of He is the ionization energy of He+.
BobRoss
34
The equation En=-Z2RH/n2 gives the energy (according to the Bohr model) of the energy levels available to an electron in any hydrogen-like atom. Calculate the second ionization energy of He(in J). The second ionization energy of He is the ionization energy of He+.
En=-Z2RH/n2 where RH=2.178x10-18J
Z=2
n=?
I don't understand which value I am supposed to use for n. When I look up the second ionization energy of He I find that the answer is 54.4 eV or 8.712x10-18J, which is the answer I get when I input n=1 into the above equation. But it's asking for the second ionization energy of He, so why would I use n=1?
n=1 is the orbit number of He. He has configuration of 1s2, meaning that both 2 electrons are in 1st orbit. 2nd Ionization energy refers to removal of 2nd electron, or removal of only electron of He+ ion, in this case.
Z refers to the atomic number of the species. For He, Z = 2.
Thanks for the question.
I think there is some problem in understanding here.
The formula En=-Z2RH/n2 can be used only for Hydrogen like atoms i.e. we can use this formula for He+ and not for ground state of Helium.
Ground state electron configuration of Helium is 1s2 while the configuration for He+ is 1s1 same as of Hydrogen.
Therefore, the energy given by En=-Z2RH/n2 will be the ionization energy for He+
The first ionization energy of He will be E1=24.5 eV and it is difficult to calculate that because of the presence of strong interactions.
Then, with this energy E1, we get He+ which is Hydrogen like atom and now we will use that formula and we get 54.4 eV.
Therefore, the process of removal of 2nd electron from He takes place in two steps ad hence the total energy required to knock off two electrons will be 24.5 eV +54.4 eV = 78.9 eV
Have a look at this article: http://lefteris-kaliambos.wikia.com/wiki/HELIUM_FIRST_IONIZATION
FAQ: Calculating second ionization energy of He
1. What is the equation for calculating the second ionization energy of He?
The equation is: IE2 = IE1 - IE1, where IE2 represents the second ionization energy and IE1 represents the first ionization energy.
2. How is the second ionization energy of He different from the first ionization energy?
The second ionization energy is the energy required to remove a second electron from a singly ionized He atom (He+). This is different from the first ionization energy, which is the energy required to remove the first electron from a neutral He atom.
3. What is the value of the second ionization energy of He?
The value of the second ionization energy of He is 54.4 eV, or 5.5 x 105 kJ/mol.
4. How does the second ionization energy of He compare to other elements?
The second ionization energy of He is relatively high compared to other elements, as it is the second smallest atom and has a stable electron configuration. This makes it difficult to remove a second electron from a He+ ion.
5. What factors can affect the second ionization energy of He?
The second ionization energy of He can be affected by factors such as the nuclear charge, shielding effect, and the distance of the outer electron from the nucleus. These factors can influence the amount of energy required to remove a second electron from the atom.
9K
23K
60K
