Calculating Signal to Noise due to thermal noise
The discussion focuses on calculating the signal-to-noise ratio (S/N) considering thermal noise and other noise sources. The equation presented indicates that total noise is a combination of thermal noise and other noise sources, but the exact value of N_other is unknown. An assumption is made that total noise equals thermal noise, leading to a simplified ratio of N_{175}/N_{275} equating to 0.80, suggesting a 20% reduction in thermal noise. Participants also question the units of N and the term √(2kTRΔf), emphasizing the need for clarity on these measurements. The conversation highlights the importance of assumptions in noise calculations, particularly when other noise sources may dominate.
JoJoQuinoa
At t = 275K, the signal to noise is S/N = 15. If the system is cooled to t = 175K, what is the S/N?
Vrms = ##\sqrt{2kTR\Delta f}##
The total noise from other sources and thermal is ##N = N_{other} + N_{thermal}##
##N_{175}/ N_{275} = (N_{other} + \sqrt{2k(175)R\Delta f})/( N_{other} + \sqrt{2k(275)R\Delta f})##
I'm not sure how to simplify the expression as ##N_{other} ## is unknown.
If I assume ##N_{total} = N_{thermal}##, then
##N_{175}/ N_{275} = \sqrt{175/275} = 0.80## meaning the thermal noise is reduced by 20% or ##(S/N)_{new} = 1.20*15 = 18##.
Is this correct?
JoJoQuinoa said:
##N_{175}/N_{275} = (N_{other} + \sqrt{2k(175)R\Delta f})/(N_{other} + \sqrt{2k(275)R\Delta f})##
What are the units of ##N##, and what are the units of ##\sqrt{2kTR\Delta f}##?
JoJoQuinoa said:
If I assume Ntotal=Nthermal,
I think you have to make this assumption, unless you have more information. Suppose the signal was huge and Nother was also huge, thermal noise could be insignificant, regardless of temperature.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
