bhuman
- 1
Hi.
I am designing a model for a vehicle. The power source is solar energy, providing power to a single 12 volt motor of about 1W. Through tests I have calculated the stall torque and max RPM of this motor, and therefore a rated torque of 0.00154 Nm. At this load the motor should ideally spin at 6000 RPM (according to tests). It is therefore necessary to use a gear system to increase the torque at the wheels and reduce the RPM so that the model is able to start moving without a clutch, and maintain a desirable speed when moving. The model weighs 8Kg and has 4 wheels of radius 4.5cm. There is no target speed, we are just aiming for maximum efficiency.
My question is, how do you calculated a gear ratio for a single gear, so that the model will move efficiently and that the motor is loaded to its rated torque.
Any help would be much appreciated!
Thanks in advance,
Ben
Thanks in advance,
Ben
