whynotzoidberg
- 1
In a reactor at the beginning of its life for every 1000 neutrons,
-450 neutrons are absorbed in U-235
-350 neutrons are absorbed in U-238
-75 neutrons are absorbed in coolant and cladding, and
-125 neutrons leak out of the reactor
nu=2.43
Note: In order to not cheat, the values of the first four quantities have been changed from the original problem. nu is constant (or nearly so) for U-235 so changing it doesn't make sense (to me anyhow). This also means that my values for the six factors (and the final answer) could be wildly off base.
[itex] k_i=ηfpε[/itex] where k_i is the Four Factor Formula; the six facor formula is
[itex] k=k_i*(P_FNL)*(P_TNL)[/itex]
the variables are...
η: reproduction factor (# fission neutrons produced per absorbtion in fuel) [itex] η=nu*((σF_f)/(σF_a))[/itex]
where nu is the average # of neutrons per fission, σF_f and F_a are "the microscopic fission cross sections for fuel, accordingly" (I think F_f is U-235 and F_a is U-238)
f: thermal utilization factor (probability that a neutron that gets absorbed does so in the fuel material) [itex] f=(ƩF_a)/(Ʃ_a)[/itex]
where ƩF_a is the macroscopic fission cross section of a (U-238?) and Ʃ_a is the total macroscopic cross section of a.
p: resonance escape probability (Fraction of fission neutrons that slow down from fission to thermal energies without being absorbed.) No equation given, can (maybe) figure out.
ε: Fast fission factor [itex] ε=(total # of fission neutrons)/(# of fission neutrons from thermal fissions only) [/itex]
P_FNL: probability of fast non-leakage
P_TNL: probability of thermal non-leakage
η is dependent on cross sections which are dependent upon energy (I wasn't given either) so I can only surmise there must be something in the given information that will suffice.
Perhaps 1000 are produced and 450+350 (900) are absorbed in fuel? So [itex] η= 10/9 =1.111...[/itex]
f: Mathematically speaking, ratio of macroscopic x-sections is no more relevant than ratio of microscopic since macro=micro*N where N is neutron density so N would cancel.
absorbed: 450+350 (900); fuel is U_235 (right?) so f = 450/900 = 0.5
p: Fissioned neutrons start of fast (high energy), go through the resonance peak (hig absorbtion) energy region, then if they survive all that go to thermal (lower energy) state. So...
I don't know. Conceptually I get it (I wrote the above line about slowing down myself) but not sure how to evaluate this.
Seems like *maybe* [itex] (total-absorbed)/total = (1000-900)/1000 = 1/10[/itex] ?
ε: total # fission neutrons is the 1000, right? And just from thermal is... I don't know. I assume it has something to do with the 450 absorbed in U-235, but that's absorbed and not fissioned. So it *could* be [itex]1000/450 = 2.222...[/itex] but that seems wrong somehow.
P_FNL *and* P_TNL: Seems like the 125 given is total leakage and so the product of the two should be [itex] (1000-125)/1000[/itex] = 0.875
If everything above is correct (which I doubt) my answer would be a pitifully low [itex]k≈0.108[/itex]
