Calculating Speed: Solving a Distance and Time Problem
  • MHB
  • Thread starter Marcelo Arevalo
  • Tags
    Speed
In summary, Ken will reach C at the same time as Mark if he continues onward, but if he turns back, he will reach B at the same time as Mark.
Marcelo Arevalo
39
Distance & Speed Problem
City B is between City A and City C.
Ken is riding a bike from B to C, a distance of 16 km.
After he has gone 6 km, Mark begins to drive a car at 60 km per hour from A to C.
If Ken continues onward, he will reach C at the same time as Mark. If he turns back, he will reach B at the same time as Mark. What is his speed, in km per hour?
- - - Updated - - -
Given :
Distance;
A ------------------ B ------------------- C
Ken is at B going to C with distance of 16 km.
B ----X-----------C
B to X is 6 km. also X to C is 10 km.
Now I am stuck.. please help.
Mathematics news on Phys.org
I don't think we can assume $B$ is midway between $A$ and $C$. Let's let:
\(\displaystyle v_K\) = Ken's speed
\(\displaystyle d_{AB}\) = distance from $A$ to $B$
\(\displaystyle t_{K_1}\) = time traveled by Ken if he turns back.
\(\displaystyle t_{M_1}=t_{K_1}-\frac{6}{v_K}\) = time traveled by Mark, if Ken turns back.
\(\displaystyle t_{K_2}=\frac{4}{3}t_{K_1}\) = time traveled by Ken if her continues.
\(\displaystyle t_{M_2}=t_{K_2}-\frac{6}{v_K}=\frac{4}{3}t_{K_1}-\frac{6}{v_K}\) = time traveled by Mark, if Ken continues.Now, if Ken turns back then he has traveled 12 km and Mark has traveled $d_{AB}$...so we may write:
\(\displaystyle 12=v_Kt_{K_1}\tag{1}\)
\(\displaystyle d_{AB}=60\left(t_{K_1}-\frac{6}{v_K}\right)\tag{2}\)
If Ken continues, then we may write:
\(\displaystyle 16=\frac{4}{3}v_{K_1}t_{K_1}\) (we have no new information here)
\(\displaystyle d_{AB}+16=60\left(\frac{4}{3}t_{K_1}-\frac{6}{v_K}\right)\tag{3}\)
We now have 3 equations and 3 unknowns...can you proceed?
Alternatively,
Let $y$ be the distance from city A to city B. Let $t_1$ be the time it takes Mark to travel from city A to city B. Let $M$ be Mark's speed and let $K$ be Ken's speed. So we have
$$M\cdot t_1=y$$
$$K\cdot t_1=6$$
Dividing these two equations gives $\dfrac MK=\dfrac y6$.
Let $t_2$ be the time it takes Mark to travel from city A to city C. Then we have
$$M\cdot t_2=y+16$$
$$K\cdot t_2=10$$
Dividing these two equations gives $\dfrac MK=\dfrac{y+16}{10}$, so we have
$$\dfrac y6=\dfrac{y+16}{10}\implies y=24\text{ km.}$$
You should now be able to complete the problem.
From your equation 1 of MarkFL post :
turn-around travel would be 12 km.
Ken on Bike; B turn Aroound to B
12/15 -->> 15km/hr assume velocity
12/15 = 0.8 hr
if he continues to the end;
16/15 = 1 1/15 hr
Mark on Car:
using Ken's end time = 1 1/15 hr X 60 kph = 64 km
A to B = 64 Km - 16 Km (B to C) = 48 Km
So: A to B
48 / 60 = 0.8 hr (Same time as Ken's Turn Around)
A to C = 48 + 16 = 64 Km
Then: 64 / 60 = 1 1/15 hr
therefore Ken's Speed is 15 Kph
Sorry I am used to a trial & error solution. I am practicing to solve mathematics problem using the algebra solutions. that's why I keep on asking for your help. so I cam polished my thoughts and put it into a detailed solutions.
Yes, I also get 15 kph for Ken...here are the 3 equations I gave:
If we solve (2) and (3) for $d_{AB}$, and equate the results, we find:
\(\displaystyle 60\left(t_{K_1}-\frac{6}{v_K}\right)=60\left(\frac{4}{3}t_{K_1}-\frac{6}{v_K}\right)-16\)
Divide through by 60:
\(\displaystyle t_{K_1}-\frac{6}{v_K}=\frac{4}{3}t_{K_1}-\frac{6}{v_K}-\frac{4}{15}\)
Add \(\displaystyle -t_{K_1}+\frac{6}{v_K}+\frac{4}{15}\) to both sides:
\(\displaystyle \frac{4}{15}=\frac{1}{3}t_{K_1}\)
Multiply through by 3:
\(\displaystyle \frac{4}{5}=t_{K_1}\)
And so (1) tells us:
\(\displaystyle v_K=\frac{12}{\dfrac{4}{5}}=15\)
However, like greg1313, I get a distance of 24 km from A to B.
Using Greg1313 :
A------------B----X-----C
AB = 24 km + BC = 16 km
t = 40 / 60 = 2/3 hr
XC = 10 km
v = 10 km / 2/3 hr = 15 Kph
To Check :
AC = 40 / 60 = 2/3 hr
XC = 10 / 15 = 2/3 hr
AB = 24/60 = 2/5 hr
XB = 6/15 = 2/5 hryes.. the speed of Ken's bike is 15 Kph.Thank you all !
FAQ: Calculating Speed: Solving a Distance and Time Problem
What is the formula for calculating distance and speed?
The formula for calculating distance is distance = speed x time. The formula for calculating speed is speed = distance / time.
How can I convert miles per hour to kilometers per hour?
To convert miles per hour to kilometers per hour, multiply the speed in miles per hour by 1.60934.
What factors can affect the accuracy of distance and speed calculations?
Factors that can affect the accuracy of distance and speed calculations include changes in speed or direction, external forces such as wind or friction, and errors in measurement or calculation.
Can distance and speed be calculated for non-linear motion?
Yes, distance and speed can be calculated for non-linear motion as well. In this case, the formula for calculating distance and speed becomes more complex and involves the use of calculus.
How do I solve distance and speed problems with multiple variables?
To solve distance and speed problems with multiple variables, you can use the equations of motion, which involve the variables of distance, speed, time, and acceleration. By rearranging the equations and using substitution, you can solve for the unknown variable.
