MHB Calculating statistical values from given data
  • Thread starter Thread starter mathmari
    Data Statistical
The discussion focuses on calculating various statistical values for the performance of a stock over ten years, including the arithmetic mean, median, mode, standard deviation, coefficient of variability, and coefficient of asymmetry. The arithmetic mean is calculated as 10.1%, with a median of 8% and a mode of 8%. The standard deviation is initially computed incorrectly, as it should account for sample size, leading to a revised calculation using n-1. The participants discuss the presence of extreme values by applying z-scores and the implications for the stock's future yield, suggesting the need for hypothesis testing to validate the analyst's claim of a 7.5% average yield next year. Overall, the conversation emphasizes the importance of correct statistical methods and interpretations in financial analysis.
mathmari
MHB
Hey! :giggle:
Analyst has collected the following data on the performance of the $X$ stock for $10$ different years.
a) Calculate the arithmetic mean, the median, the mode, the standard deviation, the coefficient of variability and of asymmetry. You interpreted your results.
b) Does the data have extreme values (consider the cut-off limit $z = \pm 2$ or $z = \pm 3$).
c) The analyst claims that the average yield next year will be at least $7.5\%$. Is the claim correct? Do you think you would have an increased risk if you bought the $X$ share?
I have done the follwoing :
a) The arithmetic mean is $$\frac{5\%+3\%+8\%+12\%+2\%+18\%+5\%+8\%+24\%+16\%}{10}=\frac{101\%}{10}=10.1\%$$
For the median, we write the percentages in an increasing order then we calculate the half of the sum of $5$-th and $6$-th percentage.
Therefore the median is equal to $$\frac{8\%+8\%}{2}=8\%$$
The modeis the value that appears most often, so $8\%$.
For the standard deviation wesubtract from eachgiven value the mean, square the result and take the sum, divide that by the number $10$ and take the square root, right?
So we get $$\sigma=\sqrt{\frac{1}{10}\left [(0.05-0.101)^2+(0.03-0.101)^2+(0.08-0.101)^2+(0.12-0.101)^2+(0.02-0.101)^2+(0.180-0.101)^2+(0.05-0.101)^2+(0.08-0.101)^2+(0.24-0.101)^2+(0.16-0.101)^2\right ]}=\sqrt{\frac{1}{10}\cdot 0.04709}\approx 0.0686$$
The coefficient of variability is $$CV=\frac{\sigma}{\mu}=\frac{0.0686}{0.101}\approx 67.92\%$$ The coefficient of asymmetry is \begin{align*}\beta_1&=\frac{1}{10}\cdot \sum_{i=1}^{10}\left (\frac{x_i-\mu}{\sigma}\right )^3\\ & =\frac{1}{10\cdot \sigma^3}\cdot \left [\left (x_i-\mu\right )^3\right ]\\ & =\frac{1}{10\cdot 0.0686^3}\cdot \left [(0.05-0.101)^3+(0.03-0.101)^3+(0.08-0.101)^3+(0.12-0.101)^3+(0.02-0.101)^3+(0.180-0.101)^3+(0.05-0.101)^3+(0.08-0.101)^3+(0.24-0.101)^3+(0.16-0.101)^3\right ]\\ & =\frac{1}{0.00322828856}\cdot 0.00221772 \\ & \approx 0.68696\end{align*}
Is everything correct so far? How can we interpret the results?
b) Could you give me a hint for that?
c) Do we have to check what distribution we have in this case? Or how can we know that?
So we get $$\sigma=...$$
First the symbols, we use the Greek symbols $\mu$ and $\sigma$ to denote the so called population mean and standard variation.
They only apply if we are measuring the whole population, and as such they are usually unknown.
We use the Latin symbols $\bar x$ and $s$ to denote the mean and standard deviation of a sample of the population. 🧐
More specifically, the formula for the standard deviation of a sample is different from the one of the entire population.
That is because we "lose a degree of freedom" since we don't know the population mean $\mu$ and can only estimate it as $\bar x$ through the same sample.
In this case it means we must divide by $n-1=10-1=9$ to find the standard deviation $s$.
So $s=\sqrt{\frac 1{10-1}\cdot0.04709}$. 🤔
It also means we have $CV=\frac{s}{\bar x}$ and $b_1 = \frac 1{n}\sum\left(\frac{x_i-\bar x}{s}\right)^3$. 🤔
The cut-off limit $z=\pm 2$ means that we look at 2 standard deviations from the mean ($\bar x\pm 2s$) and we check if we have values further away from the mean than that. 🤔
To check the claim we first formulate a null hypothesis and an alternative hypothesis, which we then try to verify.
The usual way to verify it, is by assuming that the "entire population" has a normal distribution, and that we have an independent sample of that population.
Questions (a) and (b) seem to be intended to verify if it is "reasonable" to assume a normal distribution.
It's also why question (a) asks to "interpret the results".
Assuming it is reasonable, we can do a t-test. 🤔
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
