It's because ##\frac 1r \frac \partial {\partial r} r F(r)## is only valid where F(r) is defined, and F(r)=k/r is not defined at r = 0.Miike012 said:Instead of making [1/r]d(k1)/dr = 0, I change it to k1/2 where r = 2. Then I get the correct answer.. still don't understand why though.
The Divergence Theorem is a fundamental theorem in vector calculus that relates the surface integral of a vector field over a closed surface to the volume integral of the divergence of that vector field over the enclosed volume.
The Divergence Theorem allows us to convert a surface integral into a volume integral, making it much easier to calculate and evaluate. This is because the volume integral over the divergence of a vector field is typically simpler to calculate than a surface integral.
The Divergence Theorem is significant because it provides a powerful tool for solving a wide range of problems involving surface integrals. It allows us to convert a difficult surface integral into a simpler volume integral, making calculations easier and more efficient.
Yes, the Divergence Theorem can only be used for closed surfaces, meaning that the surface must completely enclose a finite volume. Additionally, the vector field must be continuous and differentiable within this volume.
No, the Divergence Theorem is only applicable to conservative vector fields, meaning that the curl of the vector field must be equal to zero. Non-conservative vector fields may require different methods for calculating surface integrals.
