Calculating surface tension with the Capillary Equation
In summary, the Capillary Equation is a formula used to calculate the surface tension of a liquid based on its density, gravitational acceleration, and the radius of the tube or capillary in which it is contained. This equation takes into account the forces of cohesion and adhesion between the liquid and the tube walls, and can be used to determine the surface tension of various liquids, such as water, oil, and alcohol. It is commonly used in physics and chemistry experiments, as well as in industrial applications for measuring the surface tension of liquids. Overall, the Capillary Equation is a useful tool for understanding and quantifying the surface tension of different substances.
Allen Montgomery
Hello everyone, I am doing an experiment and I've hit a snag with my calculations. I am looking at how concentrations of soap affect surface tension in water. I am have been using the capillary equation and capillary tubes for my calculations. I have practiced this method for 100% water and I have gotten the value of 2.36E-05 as my surface tension of water at 70 degrees F. I would assume that doing this correctly would give me the surface tension for water at 70 degrees F but as I look at other sources the values appear to be .0644 N/M. I am unsure and am looking for help as to where my methodological errors would occur for my value to be this off. I feel like I am missing something but I am unsure as to what it is. (All units should be SI)
Here is the capillary equation and the variables:
s=(phga)/2
s= surface tension
h= sifference in height between depth of water and the liquid in the capillary tube .0193 m
p= density (of water) =1
g= gravity (9.8) m/s
a= raidus (2.5x10-4) m
Raw data (h values)
1.95cm
1.95cm
1.9cm
Av: (1.95+1.95+1.9)/3 = 1.93cm = .0193m = h
h= .0193
p =1
g= 9.8 m/s
a= 2.5x10-4 m
s=((1)(9.8)(2.5x10-4)(.0193))/2
s= 4.7285x10-5
s= 2.364E-5 (final answer)
What are the units of rho?
I am unsure as to what you are referring to, do you mean the radius of the hole? In that case it is m
The density
Should be g/ml
You’re using metric units, right? Kg/m^3?
I am supposed to be using SI units, did I miss a conversion?
What about g?
I will have to take a look at that in my calculations, I clearly missed that. I'll post my new results when I get a chance.
Thank you for the help, sir!
g/ml (grams per millilitre) is not SI. (At least, not since about 1960.)
As Chet suggested, SI would be kg/m3. There's a substantial ratio between the two.
But with that correction, you will still have less than half the value you found elsewhere. And by the way, I think the value you quote is for 70C, not 70F.
And by the way, I think the value you quote is for 70C, not 70F.[/QUOTE]
Thank you haruspex, you are correct the reference site I used was in F, after some conversion my value should be around .073-.074 N/m range.
I did make the necessary conversion for my density which did solve my issue concerning the "x10^-4" and put my value in the correct range.
However, the new value I have gotten for water is .02359 kg/s^2 which is still off. I am unsure as to where my error has occurred.
g = 9.8m/s^2
h = .0193m
a = 2.5x10^-4
p = 998.2 (more precise value for water than 1)
{(9.8)( .0193)(2.5x10^-4)(998.2)}/2 = .02395 kg/s
Also, Is kg/s^2 equivalent to N/m or is there a conversion I've missed again?
Thank you all for the help so far!
However, the new value I have gotten for water is .02359 kg/s which is still off. I am unsure as to where my error has occurred.
g = 9.8m/s
h = .0193m
a = 2.5x10^-4
Also, Is kg/s equivalent to N/m or is there a conversion I've missed again?
The units of surface tension are kg/s^2, which is the same as N/m.
Ok, that great, and I did accidentally write m/s when it was supposed to be m/s^2.
Any idea on what could have caused my value (.02359 kg/m^s) to be so far off from .073-0.74 N/m that it should be? That is the biggest issue I am having to deal with.
(Also estimated the value for Surface tension of water at 70 degrees F from the second chart in this source https://www.engineeringtoolbox.com/water-surface-tension-d_597.html)
Was the tube really only 0.5mm internal dismeter?
Or maybe some detergent residue on the glassware?
Likes Chestermiller
I used a new capillary tube for every trial so that would eliminate the detergent residue (it was a variable I discussed in my paper).
On the jar of tubes, it read 0.9mm-0.5mm, which I assumed that .5mm referred to the hole and .9mm as the total diameter. Could that be an issue?
I will double check the jar when I have a chance tomorrow though.
It's not just the tube. Any receptacle the water contacted would need to be clean of surfactants.
If the tubes all had an outside diameter of about 1mm then your interpretation is probably right.
I see what you mean, I used new plastic cups for each trial but I will have to evaluate my experiment in the near future.
But besides that are there any mathematical errors that could be of an issue?
Not that I can see.
The equation you used assumes that the contact angle was 90 degrees. Was it?
Don't you mean zero degrees?
Might be hard to judge without a microscope in a half mm tube!
As I recall, water on glass should have a zero contact angle.
It depends on which angle is being referred to. I have seen it both ways. But, by your definition, it could be as much as 20 degrees on glass. Still, this is not enough to explain the OPs experimental difference. Maybe the height was in inches instead of cm?
I can certainly say that I tried to hold the tube as upright in the experiment but I may have not been that precise with the angle of contact.
That would certainly get close.
Chestermiller said:
It depends on which angle is being referred to. I have seen it both ways. But, by your definition, it could be as much as 70 degrees on glass. Still, this is not enough to explain the OPs experimental difference. Maybe the height was in inches instead of cm?
I did check but the height was always measured in cm for my raw data then converted to m later on. I will take another look.
How would you have known? Was there a microscope in the set up?
No there was not, I simply held the tube with my hand and marked the depth and total height with a marker.
So you would not have been able to judge the contact angle. But I doubt that was a problem.
Holding the tube in your hand sounds like more of a risk. You really should have had it clamped.
Where were you making the marks? On the cup?
No there were two marks on the capillary tube itself, one for the depth (roughly 2.7cm) and one for total height (4.6, cm on average). The difference between these values should be the h values in the capillary equation.
So you were making these marks by hand, at some depth within the surrounding cup maybe?, holding the tube with the other hand, while looking down into the cup from above... All sounds a bit awkward.
Presumably the base of the tube was resting on the base of the cup. I don't think that should affect the result, but it does not sound ideal.
I was making these markings by hand, although I used a short cup so I could look at it and mark it from the side. But yes it was a bit awkward but I did get mostly consistent results in the experiment
The base of the tube was resting on the base of the cup for every trial as well.
Related to Calculating surface tension with the Capillary Equation
1. What is surface tension?
Surface tension is the measure of the force that holds the molecules of a liquid together at its surface. It is caused by the imbalance of intermolecular forces between the surface molecules and those in the bulk of the liquid.
2. How is surface tension calculated?
Surface tension can be calculated using the Capillary Equation, which takes into account the surface tension, contact angle, and radius of the capillary tube. It is expressed as γ = ρghcosθ, where γ is the surface tension, ρ is the density of the liquid, g is the acceleration due to gravity, h is the height of the liquid in the capillary tube, and θ is the contact angle.
3. What is the significance of calculating surface tension?
Calculating surface tension is important in understanding the behavior of liquids, such as their ability to form droplets or spread out on a surface. It also has practical applications in industries such as pharmaceuticals, where surface tension affects the absorption and distribution of drugs in the body.
4. What factors can affect surface tension?
Surface tension can be affected by temperature, pressure, and the presence of impurities or additives in the liquid. It can also be influenced by the type of liquid and the material of the surface it is in contact with.
5. Are there any limitations to using the Capillary Equation for calculating surface tension?
The Capillary Equation is based on certain assumptions, such as the liquid being incompressible and the capillary tube having a circular cross-section. These assumptions may not hold true in all situations, so the calculated surface tension may not be entirely accurate. Additionally, the contact angle can be difficult to measure accurately, which can also affect the results.
  • Mechanics
  • Mechanical Engineering
