Calculating Temperature of Fuel-Air Mixture
In summary: If there was fuel in the mix, the air would be heated even more and would reach a higher temperature. Vaporized fuel is not ideal for combustion, as it does not include all of the elements necessary for combustion to occur.
dboozer
In many spark-ignition engines, liquid fuel is added to the inlet air upstream of the inlet manifold above the throttle. The inlet manifold is heated to ensure that under steady-state conditions the fuel is vaporized before the mixture enters the cylinder.
At normal wide-open throttle operating conditions, in a four-stroke cycle 1.6 L (Vd) displacement four-cylinder engine, at 2500 rpm (N), the temperature of the air entering the carburetor is 40C. The heat of vaporization of the fuel in 350 kJ/kg and the rate of heat transfer to the intake mixture is 1.4 kW. Estimate the temperature of the inlet mixture as it passes through the inlet valve, assuming that the fuel is fully vaporized. The volumetric efficiency is 0.85. The air density is 1.06 kg/m^3 and cp for air is 1 kJ/kgK. You may neglect the effects of the heat capacity of the liquid and vapor fuel.
Volumetric Efficiency: Ratio of the mass of air inducted into the cylinders to the mass of ambient air
[itex]\eta_v =\frac{m_a}{\rho_a V_d}=\frac{2 \dot{m_a}}{\rho_a V_d N}[/itex]
Rate of Heat Transfer
[itex]\dot{Q} = \dot{m} c \Delta T[/itex]
Not 100% sure where to start.
Calculating the mass of air inducted into the cylinders is straightforward... I'm just not sure how to tie it all together.
The mass of air inducted into the cylinders is
0.85(1.06 kg/m^3)(1.6 L)(1 m^3/1000 L)(1000 g/kg) = 1.44 g
Since
[itex]\dot{Q}_{air}=c_p \dot{m}_a \Delta T=c_p m_a \Delta T (\frac{N}{2})[/itex],
You can calculate the change in temperature of the air to be
[itex]\Delta T = 46.62 C[/itex]
and thus the final temperature of the air is 86.62 C.
The problem says you can neglect the effects of the heat capacity of the liquid and vapor fuel, but how do I take the temperature of the fuel into account for the temperature of the mix?
No one has any input or ideas? Surely there's someone who can help me!
A friend helped me out earlier...
The fuel-air mixture is traveling through the inlet manifold toward the engine. The inlet manifold is heated so as to vaporize the fuel.
Assuming an equivalence ratio of 0.8 and a stoichiometric A/F of 14.4, one can calculate the mass of the fuel mixed with the air. Know the specific heat of vaporization of the fuel allows us to determine how much energy was absorbed by the fuel to vaporize. The rest of the energy was absorbed by the air.
The 86.62 C calculated before is the maximum value of the air during this process and assumes no fuel in the mix.
Related to Calculating Temperature of Fuel-Air Mixture
1. What is the fuel-air mixture?
The fuel-air mixture refers to the ratio of fuel and air that is present in a combustion chamber. This ratio is crucial in determining the efficiency and temperature of the combustion process.
2. How is the temperature of the fuel-air mixture calculated?
The temperature of the fuel-air mixture can be calculated using the ideal gas law, which states that the temperature is directly proportional to the pressure and inversely proportional to the volume of the gas. By knowing the pressure and volume of the mixture, the temperature can be determined.
3. What factors affect the temperature of the fuel-air mixture?
The temperature of the fuel-air mixture is affected by a variety of factors including the type of fuel used, the amount of air present, the compression ratio, and the ignition timing. Other factors such as altitude and humidity can also play a role in the temperature calculation.
4. Why is it important to calculate the temperature of the fuel-air mixture?
Calculating the temperature of the fuel-air mixture is important for understanding the efficiency of the combustion process. It also helps in determining the amount of power that can be produced by an engine, as well as the emissions that will be produced.
5. Can the temperature of the fuel-air mixture be changed?
Yes, the temperature of the fuel-air mixture can be changed by adjusting the fuel-to-air ratio or by altering other factors such as the compression ratio or ignition timing. However, it is important to carefully balance these changes to ensure optimal combustion and prevent damage to the engine.
  • Mechanical Engineering
