Calculating Tension in a horizontal cable
In summary: Fcable = (137.2N*2m*.656) / 4m * .755Fcable = 69.05NIn summary, the tension in the cable is approximately 69.05 Newtons.
rml4589
The beam is 4.0 m long and has a mass of 14.0 kg. If the beam makes an angle of 41.0 degrees with the wall, what is the tension in the cable?
The attachment is the picture to go along with visualizing the problem.
sum forces = 0
sum torqes = 0
ok so since the object is not moving, both the net force and net torque = 0. I drew a FBD with the arrows indicated in the attachment.
would I have to figure out the horizontal force from the beam and subtract it from the Tension of the cable which would be something like
cos49 = adjacent / (3.02 / cos41) = 2.63
That would be the length of the cable.
how can i calculate the tensions? I'm kinda lost at this point. thanks for your help
Not quite sure what you're doing there.
Hint: If you choose your pivot point wisely, you can solve for the tension in the cable in one step by setting net torque = 0.
i was trying to figure it out using the net forces = 0.
if i chose the pivot point being the point where the beam touches the wall, would i have to figure it out in the x and y directions? or could i just take the d to be the length of the beam?
That's not enough. Whenever you have an extended body (like a beam), be ready to use torques.
Good choice.
I don't understand what you're saying here. (What's d?)
About that pivot point, what torques act on the beam?
the only torque about that point would be the torque of the beam right?
so the torque of the beam would be offset by the tension in the cable?
sooo if i fiind the torque of the beam, that will equal the tension in the cable
or am i making up my own laws of physics here?
By "torque of the beam" I think you mean the torque due to the weight of the beam. That's one torque. The tension creates another torque.
The torque due to the weight will be balanced by the torque due to the tension.
Torque and force (such as tension) are different things with different units, so a torque cannot equal a force. (Of course they are closely related.)
Just a little. :wink:
ok i think i know what you are saying.
the torque of the cable will be equal but opposite the torque of the beam, causing a net torque of 0. using the torque of the cable i should be able to figure out the tension of the cable. since tension is just a force, and force is just ma, in this case a = 9.8, Fbeam * rbeamsin(theta) = -Fcable * rcable
since sin(90) = 1, that doesn't need to be taken into accord for the cable.
Is that equation right so far?
i would just solve for Fcable and that should be the tension.
EDIT:
would it be this equation instead?
Fbeam*rbeamsin41 = Fcable*rcable*sin49?
i realized the angle is probably 49 and not 90. i was looking at the incorrect place
Good!
Forget that last part about a = 9.8. Nothing's accelerating here.
Why do you think the angle is 90 degrees?
Put that sinθ back for the tension force.
Yes, once you fix the equation you can solve for the tension.
rml4589 said:
EDIT:
Much better! (What are rbeam and rcable equal to?)
Rbeam = 2m
Rcable = 3.02/sin41 = 4.6 / 2 = 2.3
so it would be, with everything plugged in
Fbeam*Rbeam*sin(41) = -Fcable*Rcable*sin(49)
and therefore
137.2N * 2m * .656 deg. = -Fcable * 2.3m * sin(49)
solving for Fcable
Fcable = -(137.2N * 2m * .656 deg.) / (2.3m * .755 deg.)
Fcable = -103.7 N
or would it be positive?
rml4589 said:
Rbeam = 2m
Good. The weight acts in the center of the beam.
No. The tension acts at the end of the beam, so Rcable should equal the full length of the beam.
Get rid of the minus sign. What you're really doing is setting clockwise torques (from the weight) equal to counter-clockwise torques (from tension).
ok so it would be
137.2N * 2m * .656 deg = Fcable * 4.6 * .755
Fcable = (137.2N*2m*.656) / 4.6 * .755
Fcable = 51.83N ?
How did you get 4.6? The beam is only 4 m long.
4.6 was the length of the cable not the beam.
since i know the angle between the wall and the beam, and i knew the length of the beam (the hypotenuse), i used sin41 = Lcable / 4...
which i just calculated to be 2.62 haha wow strange mistake there...
ok so 137.2N * 2m * .656 = Fcable * 2.62 * .755
Fcable = (137.2N*2m*.656) / (2.62 * .755) = 90.999 so 91 N?
The length of the cable is not what you need.
Since you are finding torques on the beam, all distances are along the beam. R is the distance from pivot to the point of application of the force on the beam. Since the weight acts at the middle of the beam, Rweight = 2m (half the length of the beam). The tension acts at the end of the beam, so what must Rtension equal?
Note: It might be less confusing if you used Fweight instead of Fbeam, since both forces act on the beam. Similarly, use Rweight instead of Rbeam.
ok you lost me :(
so Rweight is equal for both sides of the equation as well as Fweight?
or is Rtension = Rbeam?
i'm confusing myself i think
No, Rweight is equivalent to Rbeam.
All I'm suggesting here is to use the word "weight" (which describes the force) instead of the word "beam" when describing the force due to the weight of the beam.
ok, so using your suggestion, the formula is:
Fweight*Rweight* sin41 = Ftension*Rweight * sin49?
are the Rweight supposed to cancel?
if so,
Fweight * sin41 = Ftension*sin49
137.2 * sin41 = Ftension*sin49
Ftension = 119.3 N?
No, the formula should be:
Fweight*Rweight* sin41 = Ftension*Rtension * sin49
(I didn't realize that I changed "cable" to "tension" as well, so that might have confused you.)
The key thing is: What is Rtension (which you called Rcable)? Rtension and Rweight are distances that you should know.
as a pre-ps, thanks for putting up with me as long as you have haha
Rweight = 2 because the weight acts on the middle of the beam.
as for Rtension, like you said, acts on the end of the beam. so wouldn't it be the distance from the wall to the end of the beam, which happens to be Ltension?
just to make sure, the unknown is still Ftension right? and Rtension = distance from pivot point to the point of application of force. Wouldn't that distance be the length of the cable? or is the point of application of force NOT where the cable and the beam meet?
Right.
It's the distance from pivot point (at one end of the beam) to the other end of the beam. (I don't know what you mean by Ltension.)
Right.
Exactly.
No. The length of the cable is the distance from one end of the cable to the other. That has nothing to do with Rtension.
No, that's exactly where the point of application of the tension force is.
Do this: On your diagram, put a mark at the pivot and a second mark at the end of the beam where the cable is attached. The distance between those two points is Rtension. (What is that distance? Hint: It's a really easy question!)
so Rtension = length of the BEAM not the cable?
and it doesn't cancel out because Rweight = 2Rtension.
SO
137.2N * 2m * .656 deg. = Ftension * 4m * .755
and
Ftension = 59.6 N?
please tell me I'm finally right haha
Yes!
Well, you have those swapped, but yes, that's the idea. (2Rweight = Rtension.)
SO
and
Ftension = 59.6 N?
Yay!
WOOO! Thank you SO much lol. I've seriously been working on that problem for 3 days now. it was the last of my pre-final practice test. It was only worth like 1/1000 of my grade, but it will definitely help me on the final tomorrow. We got snowed in here in Mass so they moved the final to tomorrow. It was supposed to be this morning but they postponed it to tomorrow lol. There had BETTER be a question like that on the test tomorrow now that i actually know how to do it haha. thanks again!
Related to Calculating Tension in a horizontal cable
1. How do you calculate tension in a horizontal cable?
To calculate tension in a horizontal cable, you need to know the weight of the object being supported by the cable, the angle of the cable with the horizontal, and the length of the cable. You can then use the formula T = (W/sinθ) + (W/tanθ) to calculate the tension, where T is the tension, W is the weight, and θ is the angle of the cable.
2. What units are used for tension?
Tension is typically measured in units of force, such as newtons (N) or pounds (lbs). This is because tension is a force that is pulling or stretching on an object, and can be measured using a spring scale or other force-measuring device.
3. How does the angle of the cable affect tension?
The angle of the cable affects tension because as the angle increases, the horizontal component of the tension decreases and the vertical component increases. This means that the overall tension in the cable increases as the angle becomes more vertical.
4. Can you have negative tension in a horizontal cable?
No, tension in a horizontal cable can only be positive. This is because tension is a force that is pulling or stretching on an object, and negative tension would imply that the cable is pushing or compressing the object, which is not possible in a horizontal configuration.
5. Is there a maximum tension that a horizontal cable can withstand?
Yes, there is a maximum tension that a horizontal cable can withstand before it breaks. This maximum tension is determined by the strength and material of the cable, and can be calculated using the cable's breaking strength. It is important to ensure that the tension in a horizontal cable does not exceed this maximum in order to prevent any accidents or damage.
