Calculating the air venting flow rate needed during CIP of a tank
Remusco
I have an application where I must calculate the venting flowrate of air required due to temperature change when hot tank is rinsed with cool water. The tank has spray nozzles inside so it can be cleaned in place. For the properties of the air in the tank I used the CoolProps module in Python.
I used three different methods to calculate the venting flowrate, as shown below:
METHOD 1:
Python:
from CoolProp.HumidAirProp import HAPropsSI
import numpy as np
import matplotlib.pyplot as plt
tank_height=(251/12)/3.281[/ICODE]
tank_diam=(104/12)/3.281[/ICODE]
tank_volume=tank_height*np.pi*0.25*tank_diam**2[/ICODE]
#tank air state before cooling
initial_air_pressure=100594
initial_air_temp=335.928
initial_air_specific_vol=HAPropsSI('Vha','T',initial_air_temp,'P',initial_air_pressure,'R',1)
#tank air state after cooling
final_air_pressure=100594
final_air_temp=285.928
final_air_specific_vol=HAPropsSI('Vha','T',final_air_temp,'P',final_air_pressure,'R',1)
#calculating the volume displaced by the cooling
air_mass=tank_volume/initial_air_specific_vol
volume_displaced=air_mass*(final_air_specific_vol-initial_air_specific_vol)
#heat lost by the water = heat gained by the air
vdot_CIP=.0053
rho_CIP=998
C_p_water=4184
mdot_CIP=rho_CIP*vdot_CIP
deltaT=final_air_temp-initial_air_temp
Qdot=mdot_CIP*C_p_water*deltaT
#time to cool the air
C_v_air=HAPropsSI('C','T',initial_air_temp,'P',final_air_pressure,'R',1)
time=air_mass*C_v_air/(mdot_CIP*C_p_water)
print(time)
#venting flowrate
vdot_air=volume_displaced/time
print(vdot_air)
METHOD 2:
Python:
import numpy as np
vdot_CIP=.0053
rho_CIP=998
C_p_water=4184
initial_air_enthalpy=HAPropsSI('H','T',initial_air_temp,'P',initial_air_pressure,'R',1)
final_air_enthalpy=HAPropsSI('H','T',final_air_temp,'P',final_air_pressure,'R',1)
time=air_mass*(final_air_enthalpy-initial_air_enthalpy)/Qdot
print(time)
#venting flowrate
print(vdot_air)
METHOD 3:
Python:
import numpy as np
vdot_CIP=.0053
rho_CIP=998
C_p_water=4184
initial_air_enthalpy=HAPropsSI('U','T',initial_air_temp,'P',initial_air_pressure,'R',1)
final_air_enthalpy=HAPropsSI('U','T',final_air_temp,'P',final_air_pressure,'R',1)
print(time)
#venting flowrate
print(vdot_air)
My result for the vdot_air on each method is as follows:
METHOD 1:
-3.6722 kg/sec
METHOD 2:
-0.4986 kg/sec
METHOD 3:
-0.5431 kg/sec
I'm not sure why I am getting such different values for each. I know the difference lies in how I am calculating my time value; however, I would think all the methods would provide similar results.
The calculated "tank_volume" is not shown in METHOD 1:.
METHOD 3: seems to use "tank_volume" as calculated in METHOD 2:
These may or may not be part of the problem.
Have Fun!
Tom
Have Fun!
Tom
The tank volume is the same for all three.
Method 1:
This will give C_p_air. Use CV instead of C for C_v_air. (Reference)
Method 2:
You are using the correct parameter H to get the enthalpy here.
Method 3:
U is not listed in the parameter's list but I can only assume it means internal energy and not enthalpy.
You seem to want to evaluate heat lost by the water = heat gained by the air. What motivates you to use either of these methods for this purpose?
How was the temperature differential considered in method #1?
jack action said:
Method 1:
Method 2:
Method 3:
The cold rinse water will heat the cold air and cause it to contract. The vent needs to be able to suck in that displaced volume.
