Calculating the Average speed given two speeds
In summary, calculating the average speed when given two different speeds involves finding the harmonic mean if the time taken at each speed is equal. The formula is: Average Speed = 2 * (Speed1 * Speed2) / (Speed1 + Speed2). This approach is useful for scenarios where an object travels the same distance at two distinct speeds.
jnuz73hbn
Hello, I have 2 speeds and need to calculate the average speed during the time traveled
Is it possible to solve this with:
$$ v_1= 115km/h $$ $$ v_2= 60km/h $$ solution: $$ \frac {v_1 + v_2}{2} $$
No, this is not the average speed during the time travelled.
jnuz73hbn said:
Homework Statement: Hello, I have 2 speeds and need to calculate the average speed during the time traveled
You have two speeds at the same time ?
only one object that first moves at $$60km/h$$ and then at $$115km/h$$
You haven't really stated the full question. Average is a mathematical operation that can be applied to different problems in different ways. So, this may make sense if you are asking about the average result from a bunch of separate cars on a race track. But for one car driving on a highway the average speed for the whole trip is calculated from the total distance divided by the total time. For example, suppose I can drive for 10 minutes at 60mph (=10 miles) but then have to drive for 50 minutes at 30mph (=25 miles). My average speed would then be 35 miles in 1 hour.
Speed is distance divided by time. Normally you have to define what each of those are before you do the speed calculation.
Likes Orodruin, PeroK and BvU
DaveE said:
You haven't really stated the full question. Average is a mathematical operation that can be applied to different problems in different ways. So, this may make sense if you are asking about the average result from a bunch of separate cars on a race track. But for one car driving on a highway the average speed for the whole trip is calculated from the total distance divided by the total time. For example suppose I can drive for 10 minutes at 60mph (=10 miles) but then have to drive for 50 minutes at 30mph (=25 miles). My average speed would then be 35 miles in 1 hour.
i know that, but I only have two 2 speeds for a car, 60kmh in the first half of the journey and 115km/h in the second half
Always start with the definitions. What is the definition of average speed?
Likes MatinSAR
$$ v= \frac{s}{t} $$ but I dont have $$s$$ I only have two 2 speeds for a car, 60kmh in the first half of the journey and 115km/h in the second half
"half of the journey" is an important piece of information. Make up a value for total length for the trip and do the calculation. Then try it again for a different choice of total length. Does the length matter?
Or maybe "half" means half of the time. Try with different total times for the trip.
Likes MatinSAR
Nothing is given about the route, you should only calculate using this information. It means half of the time.
The route doesn't matter. Turns don't matter. The only variables that go into a speed calculation are distance and time.
If you drive halfway round a racetrack at a speed of 60 km/h and at a speed of 115 km/h for the the second half, then the average speed is not ##\frac{60 + 115} 2## km/h. That a common mistake.
"Half the journey" is not very specific. It could mean "half of the time" or "half the distance". Each of those will give different results for the average speed. You need to specify which one you mean.
Likes jbriggs444
but look, at the half of the driving time, speed is 60km/h, in the second half driving time, speed = 115km/h.
first half of time=60km/h; second half of time is 115km/h
So, if the journey takes two hours, then the first half of the journey is 60 km and the second half of the journey is 115 km?
Likes Lnewqban
So, assume that the full time is ##T##. How far do you get in the total journey? The average speed is that distance divided by ##T##.
For the other case, assume that the total distance is ##D##. How long will it the journey take travelling ##D/2## at the first speed and then ##D/2## at the second speed? The average speed is then ##D## divided by that time.
I suggest you perform both of these computations to find out that the result is not the same.
Likes MatinSAR and PeroK
$$t_1=\frac{D/2}{v_1}$$
that means:
$$v=\frac{2}{1/v_1+1/v_2}$$
is this new formula correct?
that means:
That is correct if the two distances are the same. This expression is known as the "harmonic mean".
For the case of travelling half the distance at each speed, yes. Note that it can also be written:
\frac 1v = \frac 12\left( \frac 1{v_1} + \frac 1{v_2}\right)
ie, the reciprocal of the mean speed is the average of the reciprocals of the two speeds.
The case if half the time at each velocity is different as already mentioned.
FAQ: Calculating the Average speed given two speeds
What is the formula to calculate the average speed given two speeds?
The formula to calculate the average speed given two speeds \( v_1 \) and \( v_2 \) over the same distance is: \( \text{Average Speed} = \frac{2 \cdot v_1 \cdot v_2}{v_1 + v_2} \).
Why can't we simply take the arithmetic mean of two speeds to find the average speed?
The arithmetic mean of two speeds does not account for the time spent traveling at each speed. The harmonic mean is used instead because it properly weights the speeds based on the equal distances traveled at each speed.
How does the distance traveled affect the calculation of average speed?
If the distances traveled at each speed are equal, the harmonic mean formula can be used. If the distances are different, the average speed must be calculated by considering the total distance and total time taken.
Can you provide an example of calculating average speed given two speeds?
Sure! If a car travels at 60 km/h for half the distance and 40 km/h for the other half, the average speed is calculated as follows: \( \text{Average Speed} = \frac{2 \cdot 60 \cdot 40}{60 + 40} = \frac{4800}{100} = 48 \) km/h.
What happens to the average speed if the two speeds are the same?
If the two speeds are the same, the average speed is simply equal to that speed. For example, if both speeds are 50 km/h, the average speed is also 50 km/h.
