Calculating the capacitance problem
  • Thread starter ctpengage
  • Tags
    Capacitance
In summary, the conversation discusses the behavior of an uncharged parallel-plate capacitor connected to a battery. As the potential difference of the battery increases, the depth from which electrons come in the plate (d) also increases. When d is 1 picometre, the potential difference is 20V and the gradient is equal to 5x10-14. The ratio C/A can be expressed as C/A=ε₀/d, but this does not provide a numerical solution. The meaning of "depth from which the electrons come in the plate" and the units for the gradient are not specified.
ctpengage
33
If an uncharged parallel-plate capacitor (capacitance C) is connected to a battery, one plate becomes negatively charged as electrons move to the plate face (area A). The depth d from which the electrons come in the plate in a particular capacitor is plotted against a range of values for the potential difference V of the battery. When d is one picometre, the potential difference is 20V. The gradient is equal to 5x10-14. What is the ratio C/A.
q=ε₀EA
q=CV
I combined the above two equations to get the expressions C/A=ε₀/D
However that doesn't provide me with a numerical solution for the ratio C/A.
Can anyone please help?
I don't understand what is meant by "the depth ... from which the electrons come in the plate".
Also, what is this "gradient equal to 5x10-14" mean? And what are the units?
The capacitance of a parallel-plate capacitor is given by the equation C = ε₀A/d, where ε₀ is the permittivity of free space, A is the area of the plates, and d is the distance between the plates. In this problem, we are given the potential difference V and the distance d, and we need to find the ratio C/A.
First, we can rearrange the equation for capacitance to solve for A: A = Cd/ε₀. Then, we can substitute this expression for A into the ratio C/A to get:
C/A = C / (Cd/ε₀) = ε₀ / d
Next, we can use the given information to solve for the permittivity of free space, ε₀. We know that when d = 1 picometre, V = 20V, and the gradient is equal to 5x10^-14. Using the equation for potential difference (V = Ed), we can solve for the electric field E:
E = V/d = 20V / (1x10^-12 m) = 2x10^13 V/m
Then, using the equation for electric field (E = σ/ε₀), we can solve for the surface charge density σ:
σ = ε₀E = (5x10^-14) x (2x10^13) = 1x10^-13 C/m^2
Finally, we can use the equation for surface charge density (σ = q/A) to solve for the charge q on one of the plates:
q = σA = (1x10^-13 C/m^2) x A
We can then substitute this expression for q into the equation for capacitance (C = q/V) to get:
C = (1x10^-13 C/m^2) x A / 20V = (1/20) x (1x10^-13 C/m^2) x A
Now, we can substitute this expression for C into the ratio C/A to get:
C/A = [(1/20) x (1x10^-13 C/m^2) x A] / A = (1/20) x (1x10^-13 C/m^2) = 5x10^-15 F/m^2
Therefore, the ratio C/A is equal to 5x10^-15 F/m^2.
FAQ: Calculating the capacitance problem
1. What is capacitance?
Capacitance is a measure of an object's ability to store electrical charge. It is measured in farads (F) and is determined by the geometry and material properties of the object.
2. How do you calculate capacitance?
Capacitance can be calculated using the formula C = Q/V, where C is capacitance, Q is the amount of charge stored, and V is the voltage across the object.
3. What are the factors that affect capacitance?
The factors that affect capacitance include the distance between the two conducting objects, the area of the conducting surfaces, and the dielectric constant of the material between the objects.
4. Can capacitance be negative?
No, capacitance cannot be negative. It is a physical property that describes the relationship between charge and voltage, and it is always a positive value.
5. How is capacitance used in everyday technology?
Capacitance is used in a variety of everyday technologies, such as touch screens, electronic circuits, and energy storage devices like batteries and capacitors.
