Alex_Neof
- 41
- 2
Consider a sphere of radius ##R##, with a charge density ##\rho(r)=\frac{\alpha} {r^2},## with ##\alpha## a constant. Use Gauss' law to calculate the electric field outside the sphere at a distance ##r## from the sphere's centre (ie. ##(r > R)## and inside the sphere (ie. ##(r > R).## Plot the magnitude of the electric field for both inside and outside the sphere.
Gauss' Law:
##\int\vec E.d\vec A=\frac {q_{encl}} {\epsilon_0}.##
For the first part outside the sphere ##(r > R),##
I calculated the enclosed charge as follows:
##\frac {\alpha} {R^2}\times \frac {4} {3} \pi R^3.##
Now using a Gaussian surface (sphere) of radius ##r## enclosing this charge,
## \Rightarrow E = \frac{R\alpha} {3\epsilon_0 r^2}. ##
For the second part inside the sphere ##(r < R),##
The enclosed charge now is:
##\frac {\alpha} {r^2}\times \frac {4} {3} \pi r^3.##
Using another Gaussian surface (sphere) inside, with radius ##r##,
## \Rightarrow E = \frac{\alpha} {3\epsilon_0 r}. ##
When I draw the graph, the magnitude of the E-field continues to decay with distance, but increasingly outside the sphere. Is this correct?
