Calculating the Electric field for a ring
The discussion centers on understanding why a charged ring can be replaced with two oppositely charged disks using the superposition principle. This simplification is valid as it allows for easier calculations of the electric field. The resulting charge distribution can be visualized as an annulus, where the total charge remains consistent. Participants note that while a double integral can be used for calculations, symmetry allows for a more straightforward single integral approach. Overall, the conversation emphasizes the utility of superposition in simplifying complex charge distributions.
link223
(II) A flat ring (inner radius R outer radius 4R ) is
uniformly charged. In terms of the total charge Q, determine the electric field on the axis at points (a) 0.25R and (b) 0.75R from the center of the ring. [Hint: The ring can be
replaced with two oppositely charged superposed disks.]
Gauss' Law
What i don't understand is why we are able to replace the ring with 'two oppositely charged superposed disks'?
Just trying to understand..
So we have a uniform charge which means that this'll just be a simplification of the problem than, correct?
Thanks in advance.
By the superposition principle, the solution to the sum of two charge distributions is the sum of the solutions to the separate charge distributions. If you take a small disk and a large disk with the opposite surface charge density (not charge!) then the sum of the charge distributions is an annulus as described in the problem as the resulting charge distribution within R is zero and between R and 4R there will only be the larger disc. Make sure to normalise your charge distribution such that the total charge distribution is of total charge Q.
To me, the hint makes sense if the on-axis electric field due to a uniformly disk is assumed as given and there is no requirement to derive it. If there is such a requirement, I think doing the double integral would be simpler.
Well, the double integral is also relatively easily written as a single integral just by symmetry arguments, making that approach even simpler. However, the difference in complexity is inserting zero twice in the primitive function (which evaluates to zero if you use the most convenient choice of integration constant).
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
