Maximise
- 1
Hi I am very keen to solve this problem, it is not for coursework, just something I am interested in designing.
I have attached a sketch I drew using my index finger on my laptop :)
I would like to determine the Force required of a cylinder to Lift a tilting platform.
We have two scenarios.
The platform is to move up and down between the angles shown using a cylinder of stroke 200mm.
( ~ negative 45degrees to positive 60 degrees)
The variables are the mounting positions of the cylinder.
The mass will be ~ 10kg and spread over 600mm of the platform.
The distance between the pivot and cylinder mount points are known.
Let's name coordinates from the datum (pivot) as:
horizontal coordinates x and vertical z.
Distance from pivot to cylinder mount point D.
Values in mm
Scenario A
Let's say the cylinder base
x= 15
z= -300
D = 100
Scenario B
x = 200
z = -500
D = 300
Force = mass x distance
So I could assume the centre of mass is halfway along the mass (half of 600mm).
And so I could say the force = 10 x 0.3
= 3 Nm
But would I also need to consider the angles of the cylinders? These angles will vary according to the stroke.
Hope to solve this with your help. Look forward to hearing from you :)
