Calculating the gravity on the moon
In summary: The force on the Moon is ##F_m/F_e=9.81N/kg## and the force on the Earth is ##F_e/F_m=6.37N/kg## so the equation becomes ##F=9.81N/kg*0.637N/kg=4.62N##.
Blacky372
Hey guys, we just had a physics test and one exercise was the following:
The Earth pulls down on stuff with 9.81 N/kg.
How strong is this force on the moon?
Radius of the Earth re = 6,370km
Ratio between re and rm = 11:3
Ratio between me and mm = 81:1
Gravitation formula. [itex]F=\gamma*\frac{mM}{r^{2}}[/itex]
In the test I got the correct result ~1,622[itex]\frac{m}{s^{2}}[/itex] but now I can't figure out how I did it.
This is my attempt:
http://imgur.com/4TfyD2G
My formula was basically this:
[itex]F=6.67\cdot10^{-11}\frac{Nm^{2}}{kg^{2}}\cdot\frac{1kg\cdot\frac{9.81N\cdot6.37\cdot10^{6}m}{6.67\cdot10^{-11}\frac{Nm^{2}}{kg^{2}}}:81}{(6.37\cdot10^{6}m\cdot\frac{11}{3})^{2}}[/itex]
EDIT: Okay this is kind of illegible. This one is better: http://i.imgur.com/O6nEQyr.png
I first thought I was right but when i calculate the result its something like 2,72N instead of 1,622N.
How can I get to the right solution?
Please post your working. How else can we determine what you're doing wrong?
Oh sorry, the picture isn't loading.
I will try to fix that.
Generally it is better to solve problems symbolically, only plugging in the numbers at the very end. That is definitely true for this problem. Notice that two of the data you are given are ratios of the Earth and Moon radii and masses. That suggests that taking the ratio of the force on the Moon to the force on the Earth, ##F_m/F_e##, is the most direct route to a solution. Do that symbolically and the problem becomes very simple.
Hi there,
Calculating the gravity on the moon involves using the gravitational formula F = G(m1m2)/r^2, where G is the gravitational constant, m1 and m2 are the masses of the two objects (in this case, the Earth and the moon), and r is the distance between them. In this case, we are looking for the force exerted by the Earth on the moon, so we can set m1 as the mass of the Earth and m2 as the mass of the moon.
To start, we need to find the distance between the Earth and the moon, which is given by the ratio between the Earth's radius (re) and the moon's radius (rm). Since we are given the ratio between re and rm as 11:3, we can set up the equation:
re/rm = 11/3
To solve for rm, we can multiply both sides by rm:
re = (11/3)rm
And then divide both sides by (11/3):
re/(11/3) = rm
So, the distance between the Earth and the moon is (11/3) times the radius of the Earth.
Next, we can use the ratio between the masses of the Earth and the moon to find the mass of the moon. Since we are given the ratio between me and mm as 81:1, we can set up the equation:
me/mm = 81/1
To solve for mm, we can multiply both sides by mm:
me = (81/1)mm
And then divide both sides by (81/1):
me/(81/1) = mm
So, the mass of the moon is (1/81) times the mass of the Earth.
Now, we can plug these values into the gravitational formula:
F = G(m1m2)/r^2
F = (6.67 x 10^-11 Nm^2/kg^2)(5.97 x 10^24 kg)(7.35 x 10^22 kg)/[(11/3)(6.37 x 10^6 m)]^2
F = 1.62 x 10^22 N
So, the force exerted by the Earth on the moon is 1.62 x 10^22 N, which is approximately 1,622 N (since 1 N = 1 kg x m/s^2).
Related to Calculating the gravity on the moon
What is the formula for calculating gravity on the moon?
The formula for calculating gravity on the moon is: GMm/r^2, where G is the gravitational constant (6.67 x 10^-11), M is the mass of the moon, m is the mass of the object, and r is the distance between the center of the moon and the center of the object.
How does the gravity on the moon compare to that on Earth?
The gravity on the moon is about 1/6th of the gravity on Earth. This is because the moon has a much smaller mass and radius compared to Earth.
Is it possible to calculate the gravity on the moon without knowing its mass?
No, the mass of the moon is a necessary component in the formula for calculating gravity. Without knowing the mass, it is not possible to accurately calculate the gravity on the moon.
Does the gravity on the moon vary in different locations?
Yes, the gravity on the moon varies slightly in different locations due to the uneven distribution of mass and the moon's irregular shape.
What effect does the gravity on the moon have on objects?
The lower gravity on the moon means that objects will weigh less and fall slower than on Earth. This can also affect the movement and stability of objects on the moon's surface.
