dvd_247
- 2
You have built a sensor to detect the strength of unknown magnetic fields. You
use a rectangular sample of copper that is 14.2 cm wide and 0.5 cm thick. You apply a
current of 2.4 A to the copper. You know that there is a magnetic field perpendicular
to the current because you measure a Hall Voltage of 0.1μV. What was the magnitude
of the magnetic field that you detected?
Assume that one electron per atom is available for conduction. (2) Copper has a
density of 8.93 g/cm3 and a molar mass of 63.55 g/mol. (3) Remember that 1 mol of any
substance contains 6.02 x1023 atoms (Avogadro’s number).
q vd B = q EH
VH = EH d = vd B d
n = [tex]\frac{\rho N_{A}}{M}[/tex]
B = [tex]\frac{E_{H}}{v_{d}}[/tex]
EH = [tex]\frac{V_{H}}{d}[/tex]
Therefore B = [tex]\frac{V_{H}}{v_{d} d}[/tex] ...
If vd = [tex]\frac{I}{n q A}[/tex] ...
Then B = [tex]\frac{n q A V_{H}}{I d}[/tex]
If n = [tex]\frac{\rho N_{A}}{M}[/tex]
Then B = [tex]\frac{\rho N_{A} q A V_{H}}{M I d}[/tex]
I worked out the following numbers (I don't know whether my error lies here or not)...
[tex]\rho[/tex] = 8.93 x 10-9 kgm-3
NA = 6.02 x 1023 atoms
q = 1.602 x 10-19 C
A = 14.2 x 10-2 x 0.5 x 10-2 = 7.1 x 10-4m2
VH = 0.1 x 10-6 v
M = 63.55 x 10-3 kgmol-1
I = 2.4 A
d = 0.5 x 10-2 m
I have been stuck on this question for several hours now, and can't see where I'm going wrong. The answer I'm getting is 8.018 x 10-11T, when the answer expected is between 2 and 4 T apparently. Any help would be much appreciated :)
